Author Topic: Nothing short of a Miracle  (Read 2830 times)
May 25, 2010, 03:33:25 pm
  • 3468
    • McScrubbins Body Wash
« on: May 25, 2010, 03:33:25 pm »
So i had been putting off this day for a long time as i expected it to be a very sad time of stripping down my block, taking the pan off, finding tons and tons of wreckage.
I started by pulling the oil cooler flange off and fitting my external cooler thing to it. got the pulleys off... got the dust cover off, took the clutch out & pressure plate.
To my amazement... the vacuum pump took the majority of the beating (of the IM shaft shattering) and the oil pump was fine!!!
DESPITE trying to suck up a huge amount of debris. It all got jammed inside the pick up (which had the mesh filter knocked off of it). I thought, this is too good to be true... so i opened up the pump completely (dang these oil pumps are simple!) and didn't find ANY trace of any debris going through the pump! nothing jammed & nothing had scratched the gears!!!
Hallelujah!!!!
these are just some of the bits i picked out of it
somehow nothing is jammed in the pump it's self
This is the extent of the damage to the vacuum pump
bottom of the pan...
Reply #1May 26, 2010, 06:40:09 am
NintendoKD
  • 931
    dnahtasinoivilboeraweb
    • myspace page
Re: Nothing short of a Miracle
« Reply #1 on: May 26, 2010, 06:40:09 am »
eeewww wreckage :o  like a train wreck, I just can't take my eyes off
Reply #2May 26, 2010, 06:48:40 am
« Reply #2 on: May 26, 2010, 06:48:40 am »
new "used" pickup tube for you cost of shipping :D
Reply #3May 27, 2010, 12:22:15 am
« Reply #3 on: May 27, 2010, 12:22:15 am »
both rod bolts still have the nuts on them...
Reply #4May 27, 2010, 09:58:21 am
Powered by Spearco
  • 1203
« Reply #4 on: May 27, 2010, 09:58:21 am »
Looks like mouth wash is $2.00 off  ;D.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #5May 27, 2010, 04:58:04 pm
  • 3468
« Reply #5 on: May 27, 2010, 04:58:04 pm »
Yes they do. If you read my 1.6td/aaz head thread i posted about how the failure was indeed NOT the re-use of con rod bolts but the extended use of the IM shaft bearings which had almost completely dissapeared. The IM shaft siezed on the highway and 10 seconds later the rod cap blew up. The other one was very close as well. it is blackened with burnt oil.
Compressed air cleaned the pick up right up. Thanks though :)
Reply #6May 27, 2010, 05:00:23 pm
« Reply #6 on: May 27, 2010, 05:00:23 pm »
Yeah but did it put the screen back in??? LOL. Just let me know if you need it or not as it looked like the screen was MIA.
Reply #7May 27, 2010, 08:53:10 pm
  • 2932
« Reply #7 on: May 27, 2010, 08:53:10 pm »
Great pics,.. the bolts stayed in tact, the rods broke, ha
The vacuum pump doesn't look bad in the pics.
 You know there is a seal in the base of it that seals around the oil pump shaft right?,.. old, brittle and black, it often looks like part of the pump.
Reply #8May 28, 2010, 12:07:55 pm
« Reply #8 on: May 28, 2010, 12:07:55 pm »
I'm noticing so inconsistencies here.
If the IM shaft seized your oil light should've lit, if you have a dynamic oil system then the buzzer should've gone off.
If the IM shaft seized the oil pump wouldn't have been spinning so it wouldn't have sucked up any metal.
And if the IM shaft bearing was that gone then I think the t-belt would be tracking off into the belt cover really bad.
Thoughts?
