Author Topic: Cracks in precups, Are we screwed?  (Read 2706 times)
May 19, 2010, 05:04:14 pm
sawedoffgolf
  • 213
« on: May 19, 2010, 05:04:14 pm »
Started to change a head gasket on a buddies AAZ in a mk1 and upon inspecting the head we noticed some cracks in the pre cups, I know the cracks between the valves are tolerable to a extent, how about the precups? heres some close up shots to get an idea of what we are dealing with. Looking for an opinion on what to do
Reply #1May 19, 2010, 06:44:22 pm
Re: Cracks in precups, Are we screwed?
« Reply #1 on: May 19, 2010, 06:44:22 pm »
I'm not sure what the official report on cracks in the precups is but personally I would get the injectors checked and carry on. Your cracks don't look too bad from what I can see.
If this is a high performance engine I would definitely replace them. Giles can get the 1.9 precups.
Reply #2May 19, 2010, 06:48:34 pm
« Reply #2 on: May 19, 2010, 06:48:34 pm »
I'd concur, fwiw... unless you're intending to fuel the heck out of the engine I'd say get 'er decked and away you go.
Reply #3May 19, 2010, 06:51:05 pm
rodpaslow
  • 670
« Reply #3 on: May 19, 2010, 06:51:05 pm »
I would tend to agree.  I had cracks like that and I replaced mine.  However if I hadn't planned to run it hard, I'm not so sure I would have changed them.  They look like they are tan, in my opinion Inconel or some type of nickel alloy which are superior to what I got to replace the ones I had.  Just my 2 cents.
Reply #4May 19, 2010, 08:29:27 pm
sawedoffgolf
  • 213
« Reply #4 on: May 19, 2010, 08:29:27 pm »
Thanks for the input, the engine is all stock fuel/boost levels, with that in mind we should be good to go then.
Reply #5May 20, 2010, 01:04:22 pm
  • 3468
    • McScrubbins Body Wash
« Reply #5 on: May 20, 2010, 01:04:22 pm »
Yes, granted the injectors are in fact NOT actively destroying them. Perhaps have the injectors pop and spray tested. Any truck shop can do it.
I had mine checked for free at a big rig shop. They didn't give me any numbers but they said "yupp popping within range. spray okay"
Reply #6May 20, 2010, 10:11:13 pm
sawedoffgolf
  • 213
« Reply #6 on: May 20, 2010, 10:11:13 pm »
Getting them pop tested is no issue theres a local guy who does it.
