Author Topic: radiator fan differences  (Read 4936 times)
May 17, 2010, 01:16:52 pm
jettaman8691
  • 7
« on: May 17, 2010, 01:16:52 pm »
Hello all. Question; what is the difference between a dual-fan setup for a 1995 Jetta (A3) and one for an A2 Jetta, electrically?  Does the dual fan draw more amps?  Would it fit an A2 without burning out the system?  Thanks.
Reply #1May 18, 2010, 08:24:27 pm
jettaman8691
  • 7
Re: radiator fan differences
« Reply #1 on: May 18, 2010, 08:24:27 pm »
Well, I have found a couple of things different.  The dual fan and shroud I picked up for $15 is out of a 2.0L '95 Jetta.  I want to put it into a 1989 Jetta, diesel.  The shroud from the 2.0 L'95 is much bigger than the radiator in the diesel, so I will need to shift the fans over to a dual shroud I have on hand from a wrecker.  I will need to shim out the fans from the shroud, as the '95 drive fan sticks out towards the radiator more than a normal fan would, but that is not a big problem.
$15.  Woof.  A steal compared to a new dual set. 8)
Reply #2May 24, 2010, 03:40:11 pm
« Reply #2 on: May 24, 2010, 03:40:11 pm »
2.0 shrouds are taller, and alot wider. they draw no more power, they still only have one motor driving them. passat 16v shrouds are direct bolt on for an mk2.
