Injector return line caps
Topic: Injector return line caps (Read 2207 times)
May 17, 2010, 12:23:59 pm
Dasherhead
Newbie
May 17, 2010, 12:23:59 pm »
Just order bio compatible fuel lines from Mcmaster according to the great info on this site. I don't run any more than b20. What are folks doing for the cap offs at the end of the injector return lines? Is there a good way to make your own from your own tubing?
Thanks!
79 Dasher Wagon / 06 Jetta Tdi / 81 Rabbit L
Bend, Oregon
May 17, 2010, 02:08:50 pm
GEE-BEE
Re: Injector return line caps
May 17, 2010, 02:08:50 pm »
GREASEWORKS.COM
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
May 17, 2010, 10:26:41 pm
May 17, 2010, 10:26:41 pm »
GB's just SCREAMIN it at ya! =D
must be good.
Blue 2009 CR140 Jetta CBEA/CJAA. Malone stage 2. EGR/DPF/Exhaust-valve deletes. 2.5" open exhaust. ADP Turbo swap. 1-stage nitrous kit.
THROWN ROD
May 18, 2010, 06:09:41 am
GEE-BEE
May 18, 2010, 06:09:41 am »
Sorry, my bad !
GB
Giles Pump OHC
MK1 JETTA DASH
