Author Topic: Since i have my transmission apart...  (Read 3225 times)
May 16, 2010, 03:35:13 pm
Smokey Eddy
  • 3468
    • McScrubbins Body Wash
« on: May 16, 2010, 03:35:13 pm »
I'm swapping blocks and changing clutch disks and pressure plates. While i have it apart anyone recommend any parts to replace? bearings? seals, that kind of thing. I don't know a THING about transmissions so anyone with some know how please share with me!
i'd really appreciate it. going to be buying parts soon.
for reference sake, i'll be using this site
http://www.importcarpartscanada.ca/ShopByVehicle.epc?q=1990-VOLKSWAGEN-Jetta--Gl&yearid=1990%40%401990&makeid=74%40%40Volkswagen&modelid=7337%3AA|5%3AFT|6%3ASM|4%3AEB|953%40%40Jetta+GL&catid=241185@@Transmission&mode=PS
and getting the standard 5-speed tranny gasket set but should i get all those pinion bearings and main shaft bearing and all that stuff.
« Last Edit: May 16, 2010, 03:40:52 pm by Smokey Eddy »
Ed
Reply #1May 16, 2010, 04:41:10 pm
GEE-BEE
  • 1604
Re: Since i have my transmission apart...
« Reply #1 on: May 16, 2010, 04:41:10 pm »
Look at vwtransaxles.com website for tip's
Gb
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2May 16, 2010, 04:42:39 pm
« Reply #2 on: May 16, 2010, 04:42:39 pm »
You and me both. I am going to go with brokevw for my repairs. The main thing I do know is the 020 has the self machining syndrome that is fixed with a bolt kit. I got my bolt kit from summit which matched jegs price of 52.95. I just don't have the confidence or patience to take a trans apart with no backup if I make the epic fail. BTW brokevw has this site and sells parts as well as tons of pics to help tear down a VW trans.
http://www.brokevw.com/
Reply #3May 16, 2010, 07:58:17 pm
macka
  • 957
« Reply #3 on: May 16, 2010, 07:58:17 pm »
do everything you can, its apart now, better then going a few thou k and having a part fail.
Quote from: Vincent Walden
I do know that I drive torque,  while listening to my friends prattle on about horsepower.
Reply #4May 16, 2010, 08:45:19 pm
  • 3255
    • My collection of HOWTOs
« Reply #4 on: May 16, 2010, 08:45:19 pm »
I generally do:
- both drive flange seals
- throw-out bearing
- push rod bushing
- push rod seal
- input shaft seal
- new green cover plate...obviously!
- 2.000l new tranny fluid
The Worldpac guys carry all of the seals and bushings for cheap.
I'll also inspect the push rod itself for unusual wear and reseat both drain plugs with antiseize for ease of access the next time.
« Last Edit: May 16, 2010, 10:40:01 pm by Vincent Waldon »
Reply #5May 16, 2010, 10:27:22 pm
Smokey Eddy
  • 3468
« Reply #5 on: May 16, 2010, 10:27:22 pm »
Thanks guys, exactly what i needed to know.
Ed
Reply #6May 16, 2010, 11:15:08 pm
GEE-BEE
  • 1604
« Reply #6 on: May 16, 2010, 11:15:08 pm »
Iam going to have the drain plugs made in S/S and the reverse stand bol also..
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #7May 17, 2010, 11:57:04 am
  • 3255
« Reply #7 on: May 17, 2010, 11:57:04 am »
Smokey has asked me for a little help translating between what Vince calls the parts and what the Worldpac sites call 'em:
Under "Transmission"
drive flange seals:  "final drive seal kit"   W0133-1638840
new green cover plate:  "trans. end cover gasket"  W0133-1638389  (black)
input shaft seal:  "mainshaft seal"  W0133-1641999
Under "Clutch"
throw-out bearing: "release bearing"  W0133-1633611
push rod bushing:  "clutch pushrod bushing"  W0133-1642848
push rod seal: "clutch pushrod seal" W0133-1542355
One more part I usually replace with the tranny out of the car... the starter bushing.
Under Engine Electrical:
starter bushing:  "starter bushing"  W0133-1644017
Our starters have to tug pretty hard on the flywheel those cold BC mornings and for a buck it's cheap insurance against doing the job in -30 weather!  My HOW-TOs list an easy way to get that sucker outta there.
BTW... the usual "YMMV" disclaimers apply to the above list... in particular, the Worldpac  part numbers above are illustrative... check 'em yourself for proper application against your particular vee-hickle.   ;)
Reply #8May 17, 2010, 12:08:58 pm
Smokey Eddy
  • 3468
« Reply #8 on: May 17, 2010, 12:08:58 pm »
Many thanks indeed Vince!
I promise i won't make a ticking time bomb of an engine this time.
Ed
Reply #9May 17, 2010, 12:13:31 pm
  • 3255
« Reply #9 on: May 17, 2010, 12:13:31 pm »
Hey, if they don't go boom every once in a while you're probably not pushing the envelope enough.  Gotta TDI engine on the stand at the moment that let go during a "let's see if I can free up the vanes with my right foot" experiment .... ah well.   :D
Just make sure you order yourself new rod bolts, huh??!!   ;D
Reply #10May 17, 2010, 01:17:35 pm
Smokey Eddy
  • 3468
« Reply #10 on: May 17, 2010, 01:17:35 pm »
 ;D ;Dindeed Vincent ;D ;D
sucks about the TDI though, like ... well and truely. was it an experiment done by you or the PO and you're fixing it?
I'm assuming spraying WD-40 into the intake wouldn't have freed the vanes up would it.
It would get to the vanes eventually ;) in what state thought is up for interpretation.
Ed
Reply #11May 17, 2010, 06:05:42 pm
fck
  • 70
« Reply #11 on: May 17, 2010, 06:05:42 pm »
just did everything included in waldons post a little while ago
worked great before my bottom end wore out entirely. :P
good luck have fun!
