General Information
Upgrades (non engine related )
Foamies in the Heater core
Topic: Foamies in the Heater core (Read 3427 times)
May 16, 2010, 02:10:24 pm
May 16, 2010, 02:10:24 pm »
http://www.kayakwesty.com/jettahtrcore.html
I am thinking of using these. There is no mention of what the adhesive is or what it will take heat wise. I also don't know what the temp will be in the heater box. I assume that it will be whatever temp the coolant is - a couple degrees for heat loss in the hoses to get there. Anyone know what will work as an adhesive if this isn't up to the job?
Round 2
May 18, 2010, 06:41:52 am
GEE-BEE
Re: Foamies in the Heater core
May 18, 2010, 06:41:52 am »
I have some aerospace foam .125 ( 1/8 ) thick -50 to +350 with a acyrlic backing ( sticky )
send your size and address
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
June 08, 2010, 09:37:45 am
clbanman
Cambridge, Ontario
June 08, 2010, 09:37:45 am »
I used them, made it through one winter so far. Clean the metal well first (I used brake clean). It also helps to wrap it around far enough that the material sticks to itself where the holes in the metal plate are located.
Calvin
91 VW Golf 1.6NA 5spd
General Information
