Author Topic: aaz water pump  (Read 2161 times)
May 15, 2010, 02:42:46 am
Mozza
  • 81
aaz water pump
« on: May 15, 2010, 02:42:46 am »
Hey there all, Just a Quick one today but I believe the cause of my squeeking the be the water pump bearing and when we did the cam belt the other day its as dry as a bone, but when looking at it it look like we need to remove the cam belt again to change the water pump, is this true if so or not could someone give me some guidance of how to remove it and if there is anything else i should change whilst im at it
Cheers for all your help and a cracking forum to trawl through :)
Reply #1May 15, 2010, 07:51:11 am
GEE-BEE
  • 1604
Re: aaz water pump
« Reply #1 on: May 15, 2010, 07:51:11 am »
I would do the two coolant hoses engine & upper lower radiator assy's and fresh coolant
 Hose #'s ( aaz ) engine
037 122 058  15.96
028 121 053q 18.88
autohausaz.com
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2May 15, 2010, 07:57:02 am
  • 1739
Re: aaz water pump
« Reply #2 on: May 15, 2010, 07:57:02 am »
There are some who remove the timing belt to do just the one side of the water pump, but it believe it's much less problematic to just remove the whole pump. Of course that involves some twiddling to get at the upper water pump bolts, but that's what beer and swearing was made for.
