Author Topic: tracking down a coolant leak  (Read 4828 times)
May 14, 2010, 06:37:52 am
orengutan
  • 27
« on: May 14, 2010, 06:37:52 am »
is there anything behind/between the water pump and oil pan on an aaz engine? any hoses above the pump but under the alternator that I can't see?
I'm trying to find the source of a leak. it's usually a fairly quick series of drops (up to a cup) coming from between the water pump and the oil pan. I just had the pump replaced a few months ago, so I'm not really suspecting it at the moment.
Reply #1May 14, 2010, 06:43:08 am
Re: tracking down a coolant leak
« Reply #1 on: May 14, 2010, 06:43:08 am »
Maybe this would help
I would suspect the o-ring between the block and the water pump, the o-ring for the thermostat, the thermostat housing, where the waterpump mates to the waterpump housing or the waterpump drive shaft.
Did they swap in the waterpump with housing or just the waterpump?
« Last Edit: May 14, 2010, 06:45:18 am by burn_your_money »
Reply #2May 14, 2010, 06:56:23 am
orengutan
  • 27
« Reply #2 on: May 14, 2010, 06:56:23 am »
oring between the pump and block? you mean at the head coolant flange? I just replaced that one last night. it *was* leaking, but this is a separate leak :)
I assumed the thermostat housing is the above mentioned flange, right? since it had the two sensors in it.. unless there's another one?
I think they just replaced the pump and not the housing, but I dont remember. I'll have to check.
Reply #3May 14, 2010, 06:59:36 am
orengutan
  • 27
« Reply #3 on: May 14, 2010, 06:59:36 am »
I forgot to mention two factors:
 - I sat in hot traffic for over an hour (my commutes are usually around 20 minutes at a time) the night before this issue popped up
 - one of my fuel lines was leaking a bit for a while, so I'm thinking that some fuel got somewhere it shouldn'tve and now its a leak.
Reply #4May 14, 2010, 07:04:39 am
« Reply #4 on: May 14, 2010, 07:04:39 am »
Nope. There is an o-ring between the waterpump housing and the engine block.
That's not the thermostat housing. The thermostat housing is on the bottom of the waterpump just above the power steering pump.
In this picture hose #6 connects to the thermostat housing.
If you removed the power steering pump and ran the car you would probably find your problem. Unless you have AC...
Reply #5May 14, 2010, 07:19:27 am
orengutan
  • 27
« Reply #5 on: May 14, 2010, 07:19:27 am »
oh. interesting. I didnt realize there's another thermostat, but it explains some things I was wondering about.
I'm thinking I might replace that hose first and then worry about the thermostat, since the hose is probably easier to replace (and at least then I'll be able to rule out an IP related leaks...).
Reply #6May 14, 2010, 07:42:47 am
« Reply #6 on: May 14, 2010, 07:42:47 am »
There is only 1 thermostat. The things on the flange on the front of the head are coolant temperature sensors.
You would be wise to find the actual problem and correct it. While you have the coolant drained replace any other hoses that you feel necessary. Vw's coolant system is a pain to work with.
Reply #7May 14, 2010, 07:45:06 am
orengutan
  • 27
« Reply #7 on: May 14, 2010, 07:45:06 am »
yeah. I translated both to the same word in my head :)
so I was confused why there's two thermometers, but just accepted it as Fact.
I'll try to replace that hose I mentioned first, then the housing, and THEN if the leak is still there, I guess I'll do the o-ring. may be wasteful and not so very cheap, but I'll be pretty happy if its just one of those hoses.
Reply #8May 19, 2010, 12:17:10 pm
orengutan
  • 27
« Reply #8 on: May 19, 2010, 12:17:10 pm »
closure: it was the 3 way hose. the original one was ***ed right near the thermo flange, so I couldn't see it. leak fixed.
thanks guys :)
Reply #9May 20, 2010, 09:59:48 am
« Reply #9 on: May 20, 2010, 09:59:48 am »
Good show. Thanks for following up.
Reply #10May 20, 2010, 11:22:01 am
orengutan
  • 27
« Reply #10 on: May 20, 2010, 11:22:01 am »
while I'm here doing closure, I should point out that even if you think your car has leaked dry, it hasn't. I definitely had at least another liter in there after I thought it was empty and took off the hoses.
good thing captain planet wasn't around.
Reply #11May 20, 2010, 09:39:52 pm
mystery3
  • 774
« Reply #11 on: May 20, 2010, 09:39:52 pm »
Unless you pull the thermostat the coolant never fully drains.
Ethylene glycol coolants are not very dangerous to the environment in small quantities, chemically very similar to alcohol. You should dilute it ie: hose down the area to prevent animals/children from drinking the sweet blue liquid!
