Author Topic: vacuum pump replacement how to? Oil pump replacement as well!  (Read 2190 times)
May 13, 2010, 09:04:59 am
fck
  • 70
I'm new to this
i'll also be replacing my oil pump, if i can find a new one.
vac line to the brake booster as well, just to be sure. :thumbup:
what is the inner diameter on the vac pump to brake line? i do not have an accurate caliper to measure.
what do i need to be wary of, and will I need special tools?
or is it a simple in/out?
also,
on the oil pickup tube, there is a plastic "star wars space fighter" lookin' piece.
is that necessary? mine broke into many pieces when i went to put it on a new pickup tube.
thoughts?
Reply #1May 13, 2010, 11:58:53 am
Re: vacuum pump replacement how to? Oil pump replacement as well!
« Reply #1 on: May 13, 2010, 11:58:53 am »
ok, so make sure you get the right oil pump for your vacuum pump. there are different shaft lengths. if you get too short of an oil pump, you will fire your car up to shortly find out that the oil pump wasnt turning.
Reply #2May 13, 2010, 12:04:11 pm
fck
  • 70
« Reply #2 on: May 13, 2010, 12:04:11 pm »
and how shall i check this?
i can only find this vac pump:
http://www.partsplaceinc.com/products/product-detail.aspx?sku=13743
and this oil pump:
http://www.partsplaceinc.com/products/product-detail.aspx?sku=1300
how will i know that they mate?
Reply #3May 14, 2010, 06:52:29 am
« Reply #3 on: May 14, 2010, 06:52:29 am »
What engine are we playing with? What year as well?
Reply #4May 14, 2010, 04:14:46 pm
fck
  • 70
« Reply #4 on: May 14, 2010, 04:14:46 pm »
ah.
1.6l n/a from an 86 mk2.
here is an old pic of the motor, from the weekend i brought it home. it looks much different now:
that is the vac pump where the booster hose and the yellow hose go to, correct?
