For Sale/Looking For
Parts for Sale/Wanted
shielded soft fuel return lines on tank...
Topic: shielded soft fuel return lines on tank... (Read 4018 times)
May 10, 2010, 10:38:32 pm
79rabbit4dr
May 10, 2010, 10:38:32 pm »
Both of the return lines connected between the hard lines and the fuel tank (back under the bed, below the filler tube) are leaking and I'm not sure where to buy that type of line.
Suggestions?
May 10, 2010, 10:59:01 pm
mystery3
Re: shielded soft fuel return lines on tank...
May 10, 2010, 10:59:01 pm »
I just bought a kit of viton hoses from greaseworks that included those hoses. You might want to give them a call or email. HTH
May 11, 2010, 12:47:23 am
GEE-BEE
May 11, 2010, 12:47:23 am »
It's 7 mm I.d....
The hose from the fuel tank to the filler is 42mm I.d. / 8 inches long
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
