Author Topic: washer for timing check plug (dimensions or source)  (Read 2635 times)
May 09, 2010, 01:09:25 pm
ohc
  • 13
« on: May 09, 2010, 01:09:25 pm »
Where can I find a sealing washer for the timing check plug? 1.6 NA
Thanks!
Reply #1May 10, 2010, 09:03:47 am
maxny
  • 2
Re: washer for timing check plug (dimensions or source)
« Reply #1 on: May 10, 2010, 09:03:47 am »
The washer is part of the small center plug. You can get it here-
http://www.germanautoparts.com/Volkswagen/Rabbit/Transmission/410/1
Reply #2May 10, 2010, 09:11:56 am
arb
« Reply #2 on: May 10, 2010, 09:11:56 am »
Cool !!  I didn't know they were still available - I've never replaced mine and have never had a problem with the open hole.
Reply #3May 10, 2010, 06:36:34 pm
maxny
  • 2
« Reply #3 on: May 10, 2010, 06:36:34 pm »
I never had a problem either but the open hole was bugging me. Plus if you ever get a coolant leak above the hole I don't think the anti freeze would do the clutch any good.
Reply #4May 11, 2010, 04:12:28 pm
ohc
  • 13
« Reply #4 on: May 11, 2010, 04:12:28 pm »
Sorry for the confusion, i was actually looking for the washer on the Injection Pump for the bolt you unscrew to check the timing. Looks like some questions were answered anyway!
Reply #5May 11, 2010, 05:09:54 pm
Dr. Diesel
  • 1341
« Reply #5 on: May 11, 2010, 05:09:54 pm »
Giles has them too.
Reply #6May 12, 2010, 02:43:54 am
homerj1
  • 433
« Reply #6 on: May 12, 2010, 02:43:54 am »
When I was changing engines, I had a small rag in the hole - forgot to remove it when starting the engine and behold!! it disappeared, like magic  ;)  Thankfully it hasn't caused me any issues.
aivars
Reply #7May 12, 2010, 10:26:33 pm
  • 2932
« Reply #7 on: May 12, 2010, 10:26:33 pm »
Find a local bosch service center.
 orr NAPA might have some that size.
