Author Topic: 92 TD into my 79 NA  (Read 2285 times)
May 08, 2010, 07:31:32 am
mr.bbs
  • 4
92 TD into my 79 NA
« on: May 08, 2010, 07:31:32 am »
Any additional parts I will be needing besides downpipe?  I have the engine, is it worth the swap fellers?
thanks a million
Reply #1May 08, 2010, 11:13:33 am
  • 2932
Re: 92 TD into my 79 NA
« Reply #1 on: May 08, 2010, 11:13:33 am »
Do you have the engine from the '79 too?
 I think you'll need an injection pump mounting bracket from a 1.6 engine,.. so it will match up to your alternator bracket.
Reply #2May 08, 2010, 01:47:02 pm
kaneb
  • 164
    • www.dasdubbers.org
« Reply #2 on: May 08, 2010, 01:47:02 pm »
You will need the injector pump bracket off your NA as it has the engine mount attached to it.  The mk2 set-up's IP bracket is different.
I removed all power steering pieces on my swap. Also i changes some of the coolant flanges and kept the early ones.
2004 Tdi sport-daily
1983 Rabbit TD-go kart
www.dasdubbers.org
Reply #3May 08, 2010, 10:51:45 pm
mr.bbs
  • 4
« Reply #3 on: May 08, 2010, 10:51:45 pm »
Yes, its a running 1.5 NA so I have all the pieces.  Thanks for the tips guys.  I think its worth changing out those cheap plastic coolant flange outlets too, I've seen alot of those mkII/III ones fail.  :-[
Reply #4May 09, 2010, 12:13:04 am
« Reply #4 on: May 09, 2010, 12:13:04 am »
Fuel filter relocate and airbox, both no-brainers.
Reply #5May 16, 2010, 12:43:24 am
mr.bbs
  • 4
« Reply #5 on: May 16, 2010, 12:43:24 am »
thanks, and the side mount and aircleaner...
« Last Edit: May 16, 2010, 12:45:56 am by mr.bbs »
