Author Topic: ASAP! WTB: reverse switch for an 84 rabbit, 4 speed.  (Read 7253 times)
May 07, 2010, 04:36:46 pm
ashleyroe
« on: May 07, 2010, 04:36:46 pm »
6 pin reverse light switch for a 4 speed rabbit.
pin inside broke and my reverse lights won't go off  :(
show me what you have!
thanks  :-*
Reply #1May 07, 2010, 05:54:52 pm
ashleyroe
Re: ASAP! WTB: reverse switch for an 84 rabbit, 4 speed.
« Reply #1 on: May 07, 2010, 05:54:52 pm »
bump
Reply #2May 07, 2010, 06:12:29 pm
ktzdsl
  • 73
« Reply #2 on: May 07, 2010, 06:12:29 pm »
Do you have a pic of the switch? I can check our stash tomorrow morn to verify. Do you need the switch connector at the cable or the switch off the transmission?
DFW area Texas
1982 1.6L NA diesel pickup
Reply #3May 07, 2010, 06:23:11 pm
ashleyroe
« Reply #3 on: May 07, 2010, 06:23:11 pm »
the one all the way to the right (6 pin):
Reply #4May 07, 2010, 07:41:52 pm
ktzdsl
  • 73
« Reply #4 on: May 07, 2010, 07:41:52 pm »
Will check and respond to you by 10AM CST tomorrow.
DFW area Texas
Reply #5May 07, 2010, 08:19:36 pm
  • 2932
« Reply #5 on: May 07, 2010, 08:19:36 pm »
The next one will die too.
 They can't handle the current of the reverse lights,..
 sooo Relay it when you get a new switch,..
 or make your own lever switch outside the trany,
 that the lever bumps when you go into reverse.
Reply #6May 08, 2010, 03:53:10 am
ashleyroe
« Reply #6 on: May 08, 2010, 03:53:10 am »
thank you!
Reply #7May 08, 2010, 07:50:01 am
ktzdsl
  • 73
« Reply #7 on: May 08, 2010, 07:50:01 am »
Found two (2)  switches but not of the correct gender......they are five (5) point like in the middle switch in your pics. Going to storage now to check there. Sorry.
DFW area Texas
Reply #8May 08, 2010, 08:26:52 am
ashleyroe
« Reply #8 on: May 08, 2010, 08:26:52 am »
i contacted broke, he has one for me. i'm also gonna try a 5 pin and see what it does.
thanks though!
if you do come across a 6 or if anyone does let me know, i still want 'em.
Reply #9May 08, 2010, 08:48:51 am
« Reply #9 on: May 08, 2010, 08:48:51 am »
the one with more pins is for the up shift indicator if i remember right.. and i thought the one with more pins is for a 5 speed? guess not..
Reply #10May 08, 2010, 09:13:22 am
ashleyroe
« Reply #10 on: May 08, 2010, 09:13:22 am »
no. cause that 5 speed one also works for the upshift light. suposidly the 5 pin one is the replacement for my six pin one.
but get this!
my reverse switch is unplugged right now, and my upshift light is still working....
might be because the way i ran my tach...
Reply #11May 08, 2010, 10:18:49 am
ktzdsl
  • 73
« Reply #11 on: May 08, 2010, 10:18:49 am »
No other switches here. Glad you were ale to find one.
DFW area Texas
Reply #12May 08, 2010, 11:14:43 am
ashleyroe
« Reply #12 on: May 08, 2010, 11:14:43 am »
thanks anyway!
Reply #13May 08, 2010, 11:19:48 am
  • 2932
« Reply #13 on: May 08, 2010, 11:19:48 am »
What's the trany code for this rare bird?
Reply #14May 08, 2010, 11:26:35 am
ashleyroe
« Reply #14 on: May 08, 2010, 11:26:35 am »
i have a 4A.
