Author Topic: Installing aftermarket radio in 81 rabbit, need wiring help!!!:)  (Read 15297 times)
Reply #30May 16, 2010, 09:07:19 pm
tkisling
  • 72
    My Bunneh
Re: Installing aftermarket radio in 81 rabbit, need wiring help!!!:)
« Reply #30 on: May 16, 2010, 09:07:19 pm »
it has now yellow wire. I will try using the SOURCE button to turn it on and see what happens.
Reply #31May 16, 2010, 09:27:51 pm
« Reply #31 on: May 16, 2010, 09:27:51 pm »
What yellow wire?? None of your previous posts or pictures mention a yellow wire... nor does the wiring code from Pioneer??!!   ??? ??? ???
Reply #32May 16, 2010, 11:02:19 pm
Baron VonZeppelin
« Reply #32 on: May 16, 2010, 11:02:19 pm »
On a hunch, i'm going to guess it was a small typo.
"It has NO yellow wire" ...was probably intended.
Reply #33May 17, 2010, 07:29:04 pm
tkisling
  • 72
    My Bunneh
« Reply #33 on: May 17, 2010, 07:29:04 pm »
Hooked it up today as per your instructions. No luck :(
Reply #34May 17, 2010, 08:21:12 pm
macka
  • 957
« Reply #34 on: May 17, 2010, 08:21:12 pm »
swap out the fuse and try again, I've seen fuses that look alright be bad fuses.
Quote from: Vincent Walden
Reply #35May 23, 2010, 09:02:05 pm
tkisling
  • 72
    My Bunneh
« Reply #35 on: May 23, 2010, 09:02:05 pm »
Well, after trying and trying again and again with the older Pioneer deck, I gave up and trying to install it. So I decided to wait and get a different radio. On a routine trip to Goodwill this weekend, I stumbled upon an older Kenwood AM/FM cassette deck for 9.99. I still had the box and wires and bought it since it was so cheap. I am happy to report that as of now I am blasting tunes from the radio in my Rabbit. :) The deck itself was and older design much like the factory radio. But obviously it had much newer tuning capabilities and a digital display. So I just wanted to thank you guys for dealing with me over the past week or so. :)
Reply #36May 23, 2010, 09:03:19 pm
« Reply #36 on: May 23, 2010, 09:03:19 pm »
No worries... glad to hear you got 'er running.
I'm a huge music fan as well... can't drive without tunes, right?! ;)
Reply #37May 25, 2010, 09:05:21 am
« Reply #37 on: May 25, 2010, 09:05:21 am »
just so you guys know, pioneer radios DO have a big yellow wire. steady current from the battery. i have 5 different pioneer decks in vehicles and laying in my shop. they all have a big yellow constant power wire. they have to have it to function, it powers the memory, and is the main power supply for the deck. to get a pioneer to function, you gotta have the yellow hooked to the batt +, the black hooked to a ground, and the red hooked to the switched power from the key. if someone wants to tell me again that pioneers have no yellow wire, i will gladly supply you with pictures :) ive installed more pioneer stereos than i will ever be able to count. and they all had to have the yellow wire hooked up. kinda like beating a dead horse here, but there are yellow wires on every semi-modern pioneer made within about the last 12 years..
Reply #38May 25, 2010, 01:32:08 pm
tkisling
  • 72
    My Bunneh
« Reply #38 on: May 25, 2010, 01:32:08 pm »
There was no yellow wire on MY pioneer radio.
Reply #39May 25, 2010, 02:29:43 pm
« Reply #39 on: May 25, 2010, 02:29:43 pm »
Ok, so for the record here's the Pioneer wiring color code:
Orange: constant 12v+
Red: switched 12v+
Black: ground
Green: left front +
Green/black: left front -
Gray: right front +
Gray/black: right front -
Green/red: left rear +
Black/green: left rear -
Gray/red: right rear +
Black/gray: right rear -
Blue: control output for amp or power antenna
The web site I got this from (can't find it again now, of course!) said that there are two versions of Pioneer wiring codes... and the DEH-42 is wired using old skool version.  I can believe it...it is a cassette deck, after all.... one step away from 8-track!
« Last Edit: May 25, 2010, 02:32:24 pm by Vincent Waldon »
Reply #40May 25, 2010, 04:26:30 pm
tkisling
  • 72
    My Bunneh
« Reply #40 on: May 25, 2010, 04:26:30 pm »
It's actually a cd deck. :)
Reply #41May 26, 2010, 08:46:26 am
« Reply #41 on: May 26, 2010, 08:46:26 am »
that was the only other option, the deck was ancient. usually the orange wire hooks to the dash lights, and the yellow is the memory wire. so, i guess we are both right..
