TDI Engine -General Info
Radial/axial play, how much is ok without leaks?
Topic: Radial/axial play, how much is ok without leaks? (Read 9298 times)
May 06, 2010, 04:11:57 am
svenakela
May 06, 2010, 04:11:57 am »
When I disassembled my 1Z yesterday I noticed a uge play in the turbo shaft, both radial and axial. We're talking a lot here. Like, you can move it by hand and measure the movement by eye. I have another turbo and it has less play (uge difference) so it's not a problem for me to just replace them. But has anyone experience or knowledge how much play there can be without becoming a leaking problem?
A friend of mine said the original turbo's can be rattleing like h*ll with no problem, this one is
really
rattleing though...
May 06, 2010, 11:03:35 am
svenakela
Re: Radial/axial play, how much is ok without leaks?
May 06, 2010, 11:03:35 am »
Uhhmmm, sorry for replying on my own post. Talking to myself...
I've read
http://www.vwdiesel.net/forum/index.php?topic=21899.0
and my turbo has a lot of axial, Libby's post says that's a no-no.
May 06, 2010, 03:30:49 pm
redneck_vdub
May 06, 2010, 03:30:49 pm »
From what I know and what I've heard, there can NO play at all.
'01 Golf TDI "The Redneck V-Dub"
360,000kms on the body; 17,000kms on the engine
EGR delete, 2.25" turbo back, air box mod, Giles injectors, VNT 17, ARP headstuds, 14LB flywheel, boost and EGT gauges.
Oo=w=oO
May 07, 2010, 12:27:08 am
famous phil
User+
May 07, 2010, 12:27:08 am »
Hi, Sven there should only be noticeable radial play in that type of turbo , because the main spindle floats in the oil that is forced to the bearings ( bronze bushes ) , I've found the same type ( is it KKK K14 or Garret T2 ? ) with lots of play in the spindles but the impellers weren't catching and only little oil in the intercooler pipes , I'm sure I noticed rebuild kits on Ebay not too long ago
May 07, 2010, 12:52:26 am
svenakela
May 07, 2010, 12:52:26 am »
Hmm.. good idea. eBay is my friend nowadays. The local dealer wanted €700 for a replacement turbo. I said "Okay bye bye".
I think it's a KKK, will check that up and go for eBay.
May 07, 2010, 01:18:34 am
famous phil
User+
May 07, 2010, 01:18:34 am »
I'm thinking that the 1Z might use a slightly smaller unit , the KKK's I mentioned are fitted to AAZ's 2.5TDi's and PSA XUD9 engines
May 08, 2010, 12:52:54 pm
svenakela
May 08, 2010, 12:52:54 pm »
It says Made in France and "T15". It better be a Garrett T15 then.
BTW, got a nice visitor today with a nice TDI's camper:
http://switchamotor.blogspot.com/2010/05/david-visiting-soon-of-to-cape-town.html
May 08, 2010, 05:01:47 pm
Wingaman
May 08, 2010, 05:01:47 pm »
Yes it's a GT15 from Garrett, it's smaller than a K03 from KKK.
DMF Diesel Enr. - 514-659-3041 - Spécialisation VW IDI/TDI ainsi que pompe à injection.
371-B, Ch. Ste-Marie
Ste-Marthe QC J0P 1W0
May 09, 2010, 12:08:18 am
svenakela
May 09, 2010, 12:08:18 am »
Yep, I found it via the ID-number as well.
Turbo for Ford and VAG diesel with turbocharger Garret GT1544S OEM 454083-0001/-0002
May 10, 2010, 10:56:51 am
rallydiesel
May 10, 2010, 10:56:51 am »
If there was no play at all, the shaft would bind as the turbo heats up and expands.
1991 Jetta TD - sold
2001 Golf TDI - Son's
May 11, 2010, 12:07:06 pm
superspringer
User+
May 11, 2010, 12:07:06 pm »
The tolerance of radial play on the shaft of a GT15 such as that is 10-20 thou, measured at the compressor end. Axial play is 1-4 thou.
If you say it measureable by eye then sounds like the unit is pooped! It is worth stripping the unit down though to ascertain the cause of failure - contrary to popular belief a turbocharger very rarely grenades when it feels like its had enough, 99.99% of the time there is a clear to see cause of failure. And more often than not it is oil related (either contamination or interruption of supply)
Adam
Reply #11
May 12, 2010, 02:13:43 am
svenakela
Reply #11 on:
May 12, 2010, 02:13:43 am »
Thanks guys. I've found a rebuild kit on eBay, it's not much money so I think it's worth it anyway.
--S
Reply #12
June 24, 2010, 03:29:51 am
svenakela
Reply #12 on:
June 24, 2010, 03:29:51 am »
Too much work, didn't really have time to make a follow up. Anyway, I did the rebuild yesterday and oh yes my turbo did need som love and care.
It was pretty obvious it was leaking oil when I got it off the engine.
The radial play is a lot better, of course there is some but I need to use a lot more force to move it. The axial play is totally gone.
More text and images at
http://switchamotor.blogspot.com/2010/06/turbo-rebuild-last-night_24.html
Reply #13
June 28, 2010, 01:00:23 pm
Reply #13 on:
June 28, 2010, 01:00:23 pm »
my GT17 has a butt load of play too, but it still boosts fine, and doesnt leak. but i know it could use some new wheels and bearings. it tops out at about 20 psi now, used to make 35+ psi with retarded timing when i first put it on. but it still spools fairly low, and no run away..
