Author Topic: Dodge Ve Boost pin  (Read 4853 times)
December 01, 2005, 05:43:19 pm
andy2
Dodge Ve Boost pin
« on: December 01, 2005, 05:43:19 pm »
I thought I'd show you guys this one :wink:.I know that it will work in our Ve pumps.At least it gives you the idea for fabing one up.
www.bullydog.com/shopping/pgm-more_information.php?id=631&thiscat=107&frompage=ef7da766d7&page_num=2&=SID
Reply #1December 01, 2005, 06:45:43 pm
RabbitGTDguy
  • 1274
Dodge Ve Boost pin
« Reply #1 on: December 01, 2005, 06:45:43 pm »
If you do some digging on the TDR forums there are several guys that have gone after this profile for the boost pin without having to buy the bullydog one at that cost! Only trouble is...the pins are hardened :) which makes grinding and cut a bit hard :)  Good call though...
1972 VW Westfalia
Reply #2December 01, 2005, 07:12:16 pm
andy2
Dodge Ve Boost pin
« Reply #2 on: December 01, 2005, 07:12:16 pm »
Yeah I ment to post it in the IDI section but put it here by accident.I made one up thats similar to this one.Its pretty easy to modify an AAZ one to look somthing like this for those with an otherwise useless AAZ pin :wink:
With bench grinder and 5 minutes you can add probably 5-10 Hp easy 8)
Reply #3December 02, 2005, 01:00:03 am
vwmike
  • 1158
Dodge Ve Boost pin
« Reply #3 on: December 02, 2005, 01:00:03 am »
It's funny you should post this...although I'm assuming it is in response to the thread in the vendors section. I actually got this idea some time ago and then stumbled across this while I was searching for VE pump info. I don't plan to charge anything close to what they do though.
We're looking to make it out of tool steel. It ought to be plenty hard and very wear resistant.
One thing to keep in mind though is there are in fact different diameters of LDA pins. I'm not too sure how big the dodge one is.
