1.6L NA IP distributor plunger/piston question
Topic: 1.6L NA IP distributor plunger/piston question (Read 3386 times)
May 05, 2010, 07:23:59 am
vfr750
Newbie
May 05, 2010, 07:23:59 am »
1. Does the distributor plunger/piston on a 1.6L NA I.P. have to be replaced as a pair with the distributor head or can it be replaced seperately.
2. Does anyone out there have a spare one that they are willing to part with
....preferrably in the GTA, but anywhere else will do.
Thanks
May 05, 2010, 09:06:17 am
Re: 1.6L NA IP distributor plunger/piston question
May 05, 2010, 09:06:17 am »
They are DEFINITELY a matched set - you can't replace one without the other.
May 12, 2010, 07:25:37 am
vfr750
Newbie
May 12, 2010, 07:25:37 am »
OK then...next question
Are the distributor heads/plunger interchangable between say a 1984 IP and a 92 IP, both being NA or would a turbo IP distributor be any different?
May 12, 2010, 11:17:12 am
May 12, 2010, 11:17:12 am »
my fuel pump is made from a 1.5 yellow dot casing, mostly turbo internals, a 1.6 n/a pump head, and some internal mods. a pump head is a pump head, the injection pump doesnt care.
May 12, 2010, 10:29:45 pm
May 12, 2010, 10:29:45 pm »
... unless it's a 12mm pump,
the plunger won't mwork with the cam plate,.. without machining.
May 13, 2010, 04:46:22 am
May 13, 2010, 04:46:22 am »
It's not limited to 12mm pumps where the plunger won't fit in the cam plate.
You won't run into that problem with 84/92 pumps though.
