General Information
General
ARP part numbers for 1.9 aaz
Topic: ARP part numbers for 1.9 aaz (Read 4792 times)
May 05, 2010, 01:04:35 am
May 05, 2010, 01:04:35 am »
i looked up these pages...
http://www.vwdiesel.net/forum/index.php?topic=7919.0
http://headbolts.com/Volkswagon-Audi-diesel-fasteners.html
but came up empty handed.
in specific: im looking for con rod, mains and oil pump bolts.
Also, sources for anything OEM on these would also be appreciated.
Last Edit: May 05, 2010, 01:09:58 am by Smokey Eddy
Blue 2009 CR140 Jetta CBEA/CJAA. Malone stage 2. EGR/DPF/Exhaust-valve deletes. 2.5" open exhaust. ADP Turbo swap. 1-stage nitrous kit.
THROWN ROD
May 07, 2010, 08:28:53 am
GEE-BEE
Re: ARP part numbers for 1.9 aaz
May 07, 2010, 08:28:53 am »
Derek at DMPfastners.com will help you
818-775-9804
tell him GB sent you
Iam doing a external bolt kit for the 020 trans , 12 pt s/s metric
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
May 07, 2010, 11:31:13 am
May 07, 2010, 11:31:13 am »
thanks gb!
THROWN ROD
General Information
General
