Author Topic: Moldy Door Panels  (Read 4808 times)
May 03, 2010, 09:17:50 pm
bctim
Moldy Door Panels
« on: May 03, 2010, 09:17:50 pm »
Just bought a 1987 Jetta Turbo Diesel.  It has the same problem I had on my old Jetta years ago where there was moisture that got in and created mold on the inside door panel.  Any one know where the moisture commonly comes in?  Is there a way to prevent it once I clean it up or replace the panels?
Thanks
Tim
Reply #1May 03, 2010, 09:21:52 pm
truckinwagen
  • 1895
Re: Moldy Door Panels
« Reply #1 on: May 03, 2010, 09:21:52 pm »
generally it comes in the window seals.
there are drains in the bottom of the door that ate supposed to let it out, but they can get clogged.
and there is a vapor barrier behind the door panel to keep the water out of the car, but it can get torn, etc...
I would pull the door panels, remove the vapor barrier, clean out the door drains, and then re-install a new plastic vapor barrier.
-Owen
83 Opel Kadett Diesel
Reply #2May 04, 2010, 08:23:32 pm
  • 2931
« Reply #2 on: May 04, 2010, 08:23:32 pm »
I opened a guys passenger door and it sloshed,..
 I poked at the drain holes in the bottom of the doors and it looked like a waterfall.
