Author Topic: VW 020 Trans Bolt kit ( ARP S/S 12PT) External Bolt kit )  (Read 2734 times)
May 03, 2010, 10:02:58 am
GEE-BEE
  • 1604
« on: May 03, 2010, 10:02:58 am »
Iam putting together a ARP S/S 12Point bolt kit for the VW 020's transmission's
It will be a 20 Piece kit, All bolts will be a flanged 12 pt Bolt
I HAVE A PICTURE, Email me at [email protected]
I will be having made also the reverse Stand Bolt and the drain bolt in S/S also.
let me know...
GB
« Last Edit: May 10, 2010, 05:20:34 pm by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1May 05, 2010, 12:14:46 pm
Re: VW 020 Trans Bolt kit ( ARP S/S 12PT) External Bolt kit )
« Reply #1 on: May 05, 2010, 12:14:46 pm »
whats the price going to be around?
Reply #2May 09, 2010, 02:37:17 pm
GEE-BEE
  • 1604
« Reply #2 on: May 09, 2010, 02:37:17 pm »
it's around 127.00 for the set ( 20 ) , still have two items left to make
s/s drain bollt
reverse stand bolt; 28MM WITH A 17 MM ROUND HEAD ( To seal the trans against the case)
Will advise
Iam sending another trans to vwtransaxlxes.com for a peloquin install and Overhaul.
GB
« Last Edit: May 10, 2010, 05:19:41 pm by GEE-BEE »
Giles Pump OHC
MK1 JETTA DASH
