Author Topic: Volvo and Mercedes diesel turbo's....  (Read 2409 times)
May 01, 2010, 12:01:57 pm
kaneb
  • 164
    • www.dasdubbers.org
« on: May 01, 2010, 12:01:57 pm »
Hey,
Was at my local wreckers today and saw some diesel volvos and mercedes and was curious what turbo's they have and are they the same?  I also noticed their turbo flanges(bolted up with a v band piece).  I should have taken a picture but noticed it looked a lot like the back of my turbo and was wondering if the flange would bolt up to the back of my k24?
Kane
2004 Tdi sport-daily
1983 Rabbit TD-go kart
www.dasdubbers.org
Reply #1May 01, 2010, 12:35:55 pm
Re: Volvo and Mercedes diesel turbo's....
« Reply #1 on: May 01, 2010, 12:35:55 pm »
Volvos usually have a  T3 with a flat flange, but  mine originally had a Mitsu.
Reply #2May 03, 2010, 07:50:48 am
« Reply #2 on: May 03, 2010, 07:50:48 am »
The Merc turbo is a 45 trim T3, same compressor as the VW diesel one but a bigger turbine section.  The V-band thing unbolts from the turbine outlet leaving you with the standard 4-bolt T3 outlet that fits the stock T3, not sure about the K24.  That V-band thing is Mercedes specific.  Kinda neat looking but unless you had the downpipe to cut the other end off of, you won't be able to join it to a traditional V-band.
The Volvo turbo has a different manifold mounting flange.  There are adapters to make them work on a standard T-3 flange though.  The Volvo turbo also has a .42 cold side, (same as VW and Merc) but I'm not sure on the turbine side what they are.  The Merc turbo actually spooled up about the same as the stock T3 did, maybe a tad later but not too bad.  Mine blew up because apparently I didn't rebuild it correctly.  :P
Reply #3May 08, 2010, 01:48:29 pm
kaneb
  • 164
« Reply #3 on: May 08, 2010, 01:48:29 pm »
Gotcha, Thanks!!
www.dasdubbers.org
