Author Topic: Trouble starting when parking uphill in the cold  (Read 3755 times)
April 29, 2010, 01:59:21 pm
Op-Ivy
  • 513
« on: April 29, 2010, 01:59:21 pm »
1990 1.6TD Jetta
So I have trouble starting when I park uphill and it is cold out. It will start to catch right on the first turn then just spin as if the solenoid is off. Then eventually it will start to sputter slightly on each turn and then slowly catch.
Glowplugs are fine and it starts great when not on a hill. Does anyone know what could be causing this? Fuel draining back into the tank? Surely it wouldn't drain the pump completely?
Thanks, Matt
Reply #1April 30, 2010, 10:18:43 am
Dakotakid
  • 1240
Re: Trouble starting when parking uphill in the cold
« Reply #1 on: April 30, 2010, 10:18:43 am »
I have found this to be a need to replace the input shaft seal on the pump.
Reply #2April 30, 2010, 12:29:25 pm
Op-Ivy
  • 513
« Reply #2 on: April 30, 2010, 12:29:25 pm »
Hmm I just changed that when I rebuilt my pump a few years ago. Put in new bushings as well.
I tightened up my fuel line hose clamps last night. I'll see when I leave work today if it does it again. I didn't tighten up the connection where I deleted the water separator.
Reply #3May 01, 2010, 08:32:41 am
