Author Topic: WTB - junk diesel van engine mount, ALH oil pan, Caddy window regulator  (Read 4220 times)
April 28, 2010, 10:10:14 am
Luckypabst
  • 502
Several random things I'm looking for:
- An otherwise junk 83+ diesel van rubber engine mount... I need it to take a few dimensions from the outer shell.
- ALH oil pan. The cheaper the better, damage is OK, as long as the mounting surfaces are in good shape.
- Driver's side window regulator for a Caddy. I'm not sure what would cross-over from a Rabbit - 4-door, 2-door, both?
Thanks
Chris
'82 TD Westy
'81 NA Caddy
Reply #1April 28, 2010, 02:10:35 pm
gotta have a regulator for a caddy or a 4 door car. cabby and 2 door regulators are different i believe.
Reply #2April 28, 2010, 04:49:00 pm
GEE-BEE
  • 1604
« Reply #2 on: April 28, 2010, 04:49:00 pm »
I just thru two used ones in the trash last week, Installed new in my caddy
Ask ebay seller moogie2498 if he has any more drivers side...
I ordered a rh and he shipped a lh, so I installed it and purchased another...
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #3April 28, 2010, 04:50:04 pm
  • 1739
I may have a decent pan left. I will look tomorrow.
Reply #4May 10, 2010, 10:15:08 pm
Luckypabst
  • 502
Bump...
Still looking for the engine mount and window regulator!
Thanks
Chris
'82 TD Westy
'81 NA Caddy
