Author Topic: dipstick tube won't stop leaking... help!  (Read 9823 times)
Reply #15May 05, 2010, 11:19:44 am
  • 3468
    • McScrubbins Body Wash
Re: dipstick tube won't stop leaking... help!
« Reply #15 on: May 05, 2010, 11:19:44 am »
Pretty sure the gauge is grounded as part of the cluster... and the cluster has a couple of grounds iirc but they all lead to a "star ground"... a bronze disk on the driver's side near his knees under the dash with about 15 brown wires leading to it.
I'm also pretty sure the fuel gauge and temp gauge share the same ground... since they share the same voltage stabalizer... so it's perhaps more likely the issue is a circuit board problem, a problem with the wiring between the sensor and the cluster, or with the gauge itself.
Reply #16May 06, 2010, 03:13:36 pm
superbro
  • 45
« Reply #16 on: May 06, 2010, 03:13:36 pm »
I had the same prob on my 83 caddy. It was to much pressure. All i did to fix it was run a new filter (i don't know what you call it but the round thing on the valve cover) it was clogged form something.
2005 TDI Jetta Wagon 5 speed.
 Sold :'( 1983 Caddy 1.6 N/A 5 speed. Daily driver.
