Which exhaust manifold?
Topic: Which exhaust manifold? (Read 3016 times)
April 20, 2010, 08:43:02 pm
ffgb
April 20, 2010, 08:43:02 pm »
I have a 1.6N/A. I am interested in changing the exhaust manifold. I have seen a bunch of 16v manifolds and downpipes for sale. Would this be an upgrade from the 4 into 1 that is stock on my motor? Would it be a direct fit? Who here has done anything like this? It seems that the 4 into 2 into 1 exhaust manifolds would flow better.
April 20, 2010, 09:42:53 pm
mystery3
Re: Which exhaust manifold?
April 20, 2010, 09:42:53 pm »
Do you have the toilet bowl now?
I have a couple of manifolds and dual downpipes if you're looking for one.
April 21, 2010, 08:40:49 am
GEE-BEE
April 21, 2010, 08:40:49 am »
get the toliet bowl and a 2.25 techtonics exhuast
You can add a 1Y intake also
Pic's in the for sale section
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
April 21, 2010, 08:45:25 am
April 21, 2010, 08:45:25 am »
16v manifolds wont work obviously, but the downpipe is a good upgrade if you can find the manifold for an 8v, then go for it.
April 21, 2010, 10:22:56 am
jseeley
April 21, 2010, 10:22:56 am »
In the same boat with a 1.6 NA (recent Giles pump install) thinking of changing to the 8v manifold and dual downpipe... then running 2.25 after that... what is a good muffler choice for the N/A? Is it recommended to run a resonator as well, or just straight to the muffler.
85 Golf Diesel 1.6 NA 240K miles? (odometer broken)
87 Cabriolet 1.8 Gasser 104K miles
05 Golf 2.0 Gasser 66k miles
03 Jetta Wagon TDI 112k Miles
April 21, 2010, 05:24:03 pm
Vanagoner
April 21, 2010, 05:24:03 pm »
Corrado G60 dual exhaust manifold with 30 inch double section, and magnaflow muffler. The best single power upgrade I've gotten out of a piece of steel. The second best upgrade was tearing out the small flat filter and putting in a ducted cone air filter (I haven't modded the IP at all yet).
I think the Corrado casting is an 8v, also called a 6 bolt manifold. I don't know how easily it would bolt into your application. Mine is loud, but I love the performance difference. It used to accelerate like a sailboat in a slight breeze, now it really kicks. 'Course I got my timing right about the same time as I installed the pipes, but you know.
Last Edit: April 21, 2010, 05:26:26 pm by Vanagoner
Sage
'82 Vanagon Westy, the mighty N/A
April 23, 2010, 09:18:50 am
April 23, 2010, 09:18:50 am »
the way you set up your exhaust is all about personal taste. lots of people think fart cans sound amazing, i think they sound like dog $#!t. ive also met many people that hate the sound of flowmasters, but i think nothing sounds better than a flowie. magna flows are also good mufflers, they just burn out faster than a flowie. borlas are good also, so is just about any muffler, its all about personal taste.
