Author Topic: AAZ Engine Coolant Hoses ( 3 Assys ) One Piece Design ( Silicone 5 ply )  (Read 2366 times)
April 20, 2010, 03:00:05 pm
GEE-BEE
  • 1604
If I can get 15 of you AAZ owners we can do a set of three assys for 150.00 with S/S clamps
Pump to Head : 028121053Q
Pump to oil cooler :037102258
Hardline hose to resv tank ( manual trans ) :1H0121109 R
This will one piece units, not three pieces of rubber hosewith a plastic hose in the center like the cheap replacement from Meyle.
Color: Blue, Red,Black , Yellow
Please let me know
cost 150.00
« Last Edit: April 20, 2010, 03:03:24 pm by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1April 20, 2010, 04:15:00 pm
wpinnix
  • 49
I'd be in for a set in black
Reply #2April 22, 2010, 03:54:26 pm
stewardc
Not coolant, but I just got my intake elbow. I can't wait to get the intake on my trusty AAZ.
Many thanks for the excellent service.
Reply #3April 22, 2010, 08:29:55 pm
NintendoKD
  • 931
    dnahtasinoivilboeraweb
    • myspace page
GEE BEE, I am sooo glad to see that you are no longer yelling at everyone, I wonder what happened to help this situation.  A gentleman never tells ;)  may buy some of these from you we will see, but you should move to the for sale section.  A more apropriate topic would be something to the otrder of how these hoses are indicative to having better performance 8)
thanks,
Kevin
Reply #4April 23, 2010, 08:54:47 am
GEE-BEE
  • 1604
I had to make two different mandrells for the two different Turbo applications
T2/T3/K14:  46 to 50 mm
KO3:         36 mm to 50 mm
These are special 90 degree bends on the Turbo to intake
I hope to move forward with the Coolant assy's for the AAZ's
Iam in process of doing some other products
Thanx Stew for the post !
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #5April 23, 2010, 09:40:56 am
GEE-BEE you're going to need to get vendors status from Marc in order to continue selling on here.
I'm going to lock this topic until you speak with Marc.
Thanks,
