Author Topic: AAZ Cracking pressures  (Read 1874 times)
April 20, 2010, 03:43:12 am
jeffsoldvolkshome
  • 2
« on: April 20, 2010, 03:43:12 am »
Hi All, I'm wondering what the ideal cracking pressures should be for AAZ injectors with Kerma's GTD nozzles. I'm running them in a fresh AAZ 16psi of boost, stock pump, intercooler, 2 1/2 inch exhaust, all in a Syncro Double Cab. Any help is appreciated. Jeff.
Reply #1April 20, 2010, 06:45:37 am
rabbid79
  • 684
Re: AAZ Cracking pressures
« Reply #1 on: April 20, 2010, 06:45:37 am »
As I understand it, AAZ injectors are dual stage (e.g. smaller "pilot" injection, followed by larger main injection).  I would suggest leaving them at the stock main cracking pressure which I think is 155 bar like the single stage TD injectors.  Going any higher starts to affect pump timing.
'15 WRX
