Author Topic: Could this work with aftermarket tach?  (Read 2892 times)
April 19, 2010, 02:27:12 pm
  • 3468
    • McScrubbins Body Wash
« on: April 19, 2010, 02:27:12 pm »
http://www.auberins.com/index.php?main_page=product_info&cPath=16&products_id=133&zenid=b50f1f3a543145496f74de2c6c263e54
magnetic sensor... thing
could it work for the pick up wire of an aftermarket tach?
Reply #1April 19, 2010, 02:30:46 pm
truckinwagen
  • 1895
Re: Could this work with aftermarket tach?
« Reply #1 on: April 19, 2010, 02:30:46 pm »
more than likely it will, but I am planning on using the Auber tach, as it can be used as a controller for things as well.
83 Opel Kadett Diesel
Reply #2April 19, 2010, 03:17:02 pm
  • 3468
« Reply #2 on: April 19, 2010, 03:17:02 pm »
yeah but they are digital...
the reason i ask is because i already spent the money on a tach way back when i was like 17
Reply #3April 19, 2010, 04:15:59 pm
truckinwagen
  • 1895
« Reply #3 on: April 19, 2010, 04:15:59 pm »
it is very possible that it will drive a tach, as tach's are not very fussy about the signal.
I have plans for the auber tach that do not include me watching it all the time to tell engine speed for shifting etc...
I am very confident of my abilities to chose when to shift, but I have some things that I would like to control.
being able to switch things to come on after a certain RPM, etc. is really what I am interested in.
Reply #4April 19, 2010, 05:00:52 pm
  • 3468
« Reply #4 on: April 19, 2010, 05:00:52 pm »
I just want to see how high my engine revs because i've changed the pump so drastically. I don't want to risk going over the top, you know? especially when things get loud and you lose traction at like 40mph in 3rd.
Also its good for setting idle.
most seriously, most because i already bought the tach. I'd be happy with one of those boxes too. especialyl because you could really put numbers to everything.
rpm, distance, fuel consumption, running temps all sorts of stuff.
Reply #5April 19, 2010, 07:41:33 pm
RadoTD
  • 513
    Stage WTF
« Reply #5 on: April 19, 2010, 07:41:33 pm »
You could actually set up the Auber tach as a rev limiter... just have it cut power from the fuel shutoff solenoid at a particular RPM.
Biggest problem I see is that cutting fuel instantly hits pretty hard. My solenoid shut off wire broke off once while I was at full throttle, I was actually afraid I had blown something in my engine!
And Eddy, I'm going to be putting an order in through Auber's website for some gauges for myself, so let me know if you're going to buy something from there so we can save on shipping! :)
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #6April 19, 2010, 07:45:16 pm
truckinwagen
  • 1895
« Reply #6 on: April 19, 2010, 07:45:16 pm »
I have big plans for the auber gauges...
I will be spending $700 or so there in the fall.
Reply #7April 19, 2010, 07:49:03 pm
RadoTD
  • 513
    Stage WTF
« Reply #7 on: April 19, 2010, 07:49:03 pm »
Oh wow, I'm not going that crazy. Just boost/egt, planning to mount them under the speaker grill in my dash and have it pop up when I turn the ignition on
Reply #8April 19, 2010, 07:56:59 pm
truckinwagen
  • 1895
« Reply #8 on: April 19, 2010, 07:56:59 pm »
like I said, big plans...
I will be using them as gauges, but also to control a myriad of stuff under the hood.
the water/meth sprayer(and perhaps nitrous down the line) will be triggered by RPM and EGT so that it will spray only over a certain temp and only come on over a certain RPM(have not decided on the values yet) and possibly in more than one stage.
other things come to mind, including a boost bypass controlled by lots of things.
also the auber gauges(some of them anyway) will output to a datalogger, so I will be getting one of those as well, so I can plot intake pressure/temp, EGT, oil temp, water temp, RPM, etc...
then I can graph such things before and after mods to see what effect they have.
I can also very accurately measure acceleration(either RPM of the motor, or actual speed) over time, to quantify power gains.
it is a bit much, I admit, but when you decide to toss a supercharger on your car you have to go all out!
-Owen
Reply #9April 20, 2010, 10:59:54 am
GTD.
  • 183
    • http://tinyurl.com/6yk84
« Reply #9 on: April 20, 2010, 10:59:54 am »
I wonder if the Clifford/DEI Diesel RPM Monitoring Module 2 would work, it tywraps on the alternator lead, I bought one for my Clifford alarm install but it works ok off the W terminal
[Oo=w=oO]Golf GTD
VW Diesel Mehr Kraft. Weniger Verbrauch, Aus Liebe zum Automobil
