Author Topic: So I want to do an engine swap  (Read 8065 times)
Reply #15April 20, 2010, 08:34:00 pm
  • 3255
    • My collection of HOWTOs
Re: So I want to do an engine swap
« Reply #15 on: April 20, 2010, 08:34:00 pm »
1.9 should pretty much be the same... it's the passenger mount that's the biggie.
Reply #16April 20, 2010, 08:36:21 pm
« Reply #16 on: April 20, 2010, 08:36:21 pm »
the engine swap itself I am not to worried about. its the getting the 1.9 to fit correctly and have mounts line up i am in turmoil about. ;)
I think i will be using my old trans
Reply #17April 20, 2010, 11:54:51 pm
maxfax
  • 2126
« Reply #17 on: April 20, 2010, 11:54:51 pm »
Just buy a Prius and be done with it...     ;D
Reply #18April 21, 2010, 07:15:58 am
catlin_cava
  • 1954
« Reply #18 on: April 21, 2010, 07:15:58 am »
I Think Jeremy MIGHT want the ability to stop ;D
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #19April 21, 2010, 09:18:11 am
« Reply #19 on: April 21, 2010, 09:18:11 am »
Some 1.9 pumps mount the exact same as the 1.6 pumps. It's the 2 piece ones that are different. If you get a single piece pulley just use the mk1 motor mounts, swap the mk1 coolant flanges and bolt your tranny up to it and away you go. Exhaust will be different as well.
If you do get the 2 piece pump style then you need to modify the mounting bracket. It's a matter of using a mk1 gasser motor mount and cutting the stock mk1 diesel one.
Reply #20April 21, 2010, 07:00:23 pm
« Reply #20 on: April 21, 2010, 07:00:23 pm »
After really taking a look at most vehicles driving around.. it appears they are all TDI Mk4's...
Should I bite the bullet and start to put together a TDI swap piece by piece?
Reply #21April 21, 2010, 07:25:23 pm
  • 3255
« Reply #21 on: April 21, 2010, 07:25:23 pm »
As first swaps go I'd personally not recommend a TDI... it's an orders-of-magnitude increase in complexity due to all the electronics:  under the hood (ECU etc), the cluster, the immobilizer ignition system (post 2000), and the mechanical stuff: the speedo, the clutch, shifter, the pedal cluster...etc etc etc.
« Last Edit: April 22, 2010, 09:49:59 am by Vincent Waldon »
Reply #22April 22, 2010, 09:33:03 am
« Reply #22 on: April 22, 2010, 09:33:03 am »
Plus if you get a mk4 TDI you will need custom motor mounts. If you get one from a mk3 then it is bolt in.
