Author Topic: 3 foot pry bar to time a 1.6TD pump???  (Read 2216 times)
April 17, 2010, 09:31:03 am
James8485
  • 223
« on: April 17, 2010, 09:31:03 am »
i am no expert but should you need to use a 3 foot pry bar to pry pump away from the motor to set the pump timing??
like i thought just little moves makes a big differnce,,,,,,
like if you had to pry the pump as far away from the motor as a pry bar would let you would it not be rediculouly retarted in timing????
if it was really really retarted would the cold start lever have no effect?  also when a 1.6TD is really retarted couild this cause alot of smoke and loss of power>
Cheers,
James
---------James--------
Reply #1April 17, 2010, 09:54:53 am
rallydiesel
  • 1880
Re: 3 foot pry bar to time a 1.6TD pump???
« Reply #1 on: April 17, 2010, 09:54:53 am »
You should only move the pump by hand. If you need to move the pump further from the engine than you can by hand, you need to move the belt over a tooth. Otherwise you are just bending the hardlines and eventually damaging the pump housing/mounting bolts.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2April 17, 2010, 12:41:43 pm
« Reply #2 on: April 17, 2010, 12:41:43 pm »
Cheers,
James
The cold start lever will always effect the timing, the cold start mechanism is internal so the position of the pump won't effect it. The CS knob only advances a couple degrees so at really bad timing it may not be able to bring the timing into spec.
Retarded timing will easily mess up the power and cause smoke.
The search is your friend. ;)
Reply #3April 17, 2010, 02:29:28 pm
James8485
  • 223
« Reply #3 on: April 17, 2010, 02:29:28 pm »
thanks rabbitman
will try out ifs it warm out tomorrow!!   he pried the pump away from the motor so it could be really retarted as he was really pulling on it....
hope this fixes it!!
again thanks for the response!
