Author Topic: New head install leaked coolant  (Read 5070 times)
April 13, 2010, 06:25:22 pm
chrisrandle1
  • 32
« on: April 13, 2010, 06:25:22 pm »
Hello;
Today my friend and I was trying to finish up my new head install and went to fill up the coolant and it started pooring out the head.  Rechecked the torque, seemed to be fine.  I chased all of the threads when I installed the studs. I used the provided lube on the threads.
Proth Head
ARP Studs Torqued to 90ft/lbs
New Valves $220
When we pulled the head back off it seemed like only half of the headgasket was crushed.
Any ideas you guys can offer would be great.  Any additional information you may need I will provide.
Thanks again
-Chris ???
1992 EcoDiesel - Soon to have P n P Head, T3 Turbo and more!!!
Reply #1April 13, 2010, 06:34:53 pm
zagarus
  • 619
Re: New head install leaked coolant
« Reply #1 on: April 13, 2010, 06:34:53 pm »
is it a new head?  Has it been decked before you put it on?  Is the head warped? Also did you torque the studs in the correct sequence?
Project 1.9TD Jetta Coupe Completed. Back in action!
Reply #2April 13, 2010, 06:59:07 pm
chrisrandle1
  • 32
« Reply #2 on: April 13, 2010, 06:59:07 pm »
Yes new head, correct torque pattern.
Reply #3April 13, 2010, 06:59:58 pm
truckinwagen
  • 1895
« Reply #3 on: April 13, 2010, 06:59:58 pm »
what kind of headgasket?
83 Opel Kadett Diesel
Reply #4April 13, 2010, 07:20:24 pm
speedy
  • 120
« Reply #4 on: April 13, 2010, 07:20:24 pm »
The very first thing I would do is check the head with a straightedge to be sure it is flat.  If only half of the gasket was crushed and coolant poured out, it would have to have a huge amount of runout, maybe even enough to see with the naked eye.  But any metal ruler should reveal that problem in just a few seconds.
-David
Reply #5April 13, 2010, 07:34:38 pm
chrisrandle1
  • 32
« Reply #5 on: April 13, 2010, 07:34:38 pm »
Thanks for the quick response. Head is perfectly flat, triple checked it. :)  Headgasket is a cheap one $10, however before installing it I checked it with digital calipers and it was the right thickness and the same everywhere on the gasket.  Which brand do guys you recomend since I get to replace it now?  Ive been thinking about it and was wondering if it could have something to do with the ARP studs?  I know I used the right ones I got the info from this page and they screwed in right with the proper amount above the head.
Thanks again
-Chris
Reply #6April 13, 2010, 08:00:24 pm
rabbitman
  • 2788
« Reply #6 on: April 13, 2010, 08:00:24 pm »
Is it a hydraulic head, block and gasket or a mix of hydro and mechanical stuff?
What engine?
Reply #7April 14, 2010, 11:58:03 am
chrisrandle1
  • 32
« Reply #7 on: April 14, 2010, 11:58:03 am »
hey;
It is a 1V engine in its orignal 1992 Ecodiesel Jetta, hydrolic head and block.
Thanks
-Chris
Reply #8April 19, 2010, 04:45:07 am
chrisrandle1
  • 32
« Reply #8 on: April 19, 2010, 04:45:07 am »
Any other ideas?  I am still thinking I did something wrong with the ARP Head Studs.  I ordered bolts so I will give that a try.
-Chris
Reply #9April 19, 2010, 06:34:43 am
Mark(The Miser)UK
  • 1557
« Reply #9 on: April 19, 2010, 06:34:43 am »
-Chris
Does one set of studs have standard threads, and one set, fine? [ARP/Raceware] Did you use wrong torque?
Exactly which areas of the gasket were not crushed?
Mark-The-Miser-UK
Reply #10April 19, 2010, 08:30:57 am
  • 3255
    • My collection of HOWTOs
« Reply #10 on: April 19, 2010, 08:30:57 am »
From a certain beloved provider of discount offshore parts?
Reply #11April 19, 2010, 08:37:48 am
Dakotakid
  • 1240
« Reply #11 on: April 19, 2010, 08:37:48 am »
Focus on what Libby is asking you two stories up.
I think he is on target.
Reply #12April 19, 2010, 08:45:21 am
« Reply #12 on: April 19, 2010, 08:45:21 am »
pics of how it went in maybe helpful as well.
Reply #13April 22, 2010, 08:32:34 pm
chrisrandle1
  • 32
« Reply #13 on: April 22, 2010, 08:32:34 pm »
Sorry for the slow response, libbybapa can you ask your question in a different way I don't fully understand it.
The crank was on TDC the cam was locked at TDC.
All of the head studs were the same.  ARP is the brand.
Yes the head gasket was from our famous friend.  BTW  I have had a lot of luck with his stuff until this point and I am not sure it has anything to do with his parts which is why I ordered more from him.  I already have so much money invested into this whole project that it has broke me a couple times over.
I will work on getting photos, I am fairly sure that it crushed 1 and 2 but not 3 or 4.
Thanks again
-Chris
Reply #14April 22, 2010, 08:46:54 pm
  • 3255
« Reply #14 on: April 22, 2010, 08:46:54 pm »
Andrew's asking about TDC on the cam 'cause if you try to bolt the head down at TDC without the valves also setup for TDC the piston/valve jam that results can prevent the head from being torqued down properly.
The reason I asked about the quality of the parts because other than Andrew's suggestion it's hard to think of any reason why a gasket wouldn't compress properly, assuming the surfaces are flat, head torqued in sequence etc,  unless the gasket itself is malformed.
