Author Topic: ARP main & rod studs necessary?  (Read 2695 times)
April 13, 2010, 02:01:19 pm
VW Smokr
  • 114
« on: April 13, 2010, 02:01:19 pm »
This engine build is utilizing a new German VW "fitted block", and will not be pushing much over 10-12psi boost. Already have Racewear's head studs.
Is it necessary or highly advisable to upgrade to ARP or Raceware studs for the rods and mains also for this 1.6TD? Do the stock, used rod fasteners even need to be replaced? TIA
J.R.
SoCal
Reply #1April 14, 2010, 09:34:32 am
rabbid79
  • 684
Re: ARP main & rod studs necessary?
« Reply #1 on: April 14, 2010, 09:34:32 am »
At those boost levels, which aren't much higher than stock, I'm sure you'll be fine with standard factory hardware.  I'm not sure about replacing the rod bolts.  I really don't think they need to be replaced, especially when you consider that they have to be pressed out of the rods to do so.  I think I read somewhere that the nuts need to be replaced though.
'15 WRX
Reply #2April 14, 2010, 01:06:31 pm
monomer
  • 414
« Reply #2 on: April 14, 2010, 01:06:31 pm »
Con rods get "refurbished" when you take them to the shop with arp hardware.
they machine down the cap and re-size.
www.michiganvw.org
Reply #3April 15, 2010, 04:20:37 am
Kudagra
  • 738
    • www.no-coast.com
« Reply #3 on: April 15, 2010, 04:20:37 am »
J.R.
SoCal
12psi on a diesel is like spitting in the ocean.
Turbo boost libido and passive restraints
And as of yet I haven't heard even a single complaint
I've got the tools of the trade and a fuel injected heart
Efficiency is beautiful, efficiency is art
Reply #4April 15, 2010, 10:02:13 am
« Reply #4 on: April 15, 2010, 10:02:13 am »
im running around 25 psi on a bone stock 1.5, and they have the weakest heads and blocks. some people on the forum are running 40+ psi in their engines.
so, yea, 12 psi is like spitting in the ocean. lol
8-10 psi is stock boost levels BTW.
Reply #5April 15, 2010, 01:56:18 pm
VW Smokr
  • 114
« Reply #5 on: April 15, 2010, 01:56:18 pm »
That's good news. I'll just get new nuts for the rod bolts then. Thanks all.
J.R.
SoCal
