Author Topic: More power from your Alternator !  (Read 2280 times)
April 07, 2010, 05:16:04 pm
GEE-BEE
  • 1604
« on: April 07, 2010, 05:16:04 pm »
I had a local stereo shop make me a 38 inch long #4 gauge wire with 5/16 end leads, got rid of that crappy stock stuff....
More power now Scotty !
GB
oh yeah 12.00 buck's
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1April 07, 2010, 10:46:15 pm
mystery3
  • 774
Re: More power from your Alternator !
« Reply #1 on: April 07, 2010, 10:46:15 pm »
How much shipped to 94086?
Also with all the stuff you're doing in silicone are you making hose kits for the 1.6's?
Reply #2April 08, 2010, 07:23:34 am
GEE-BEE
  • 1604
« Reply #2 on: April 08, 2010, 07:23:34 am »
ADD 4.90 FOR SHIPPING, I CAN GET ONE MADE UP FROM MY LOCAL SHOP
Iam finishing the1.6 TD and 1.9AAZ intake ducts and wanted to finish the Tiico kit's next..
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #3April 08, 2010, 01:42:55 pm
GTD.
  • 183
    • http://tinyurl.com/6yk84
« Reply #3 on: April 08, 2010, 01:42:55 pm »
You should see the cables I'm making this weekend for the battery to starter, starter to Alternator, and transmission to battery I believe its arround 3/0 AWG
The cable is from a E30 BMW with boot mounted battery
Just got the M10 cable lugs today for the alternator & starter motor + terminals and for the transmission ground
going to link the battery directly to the transmission ground then from the trans ground to the body ground in 4 AWG cable
Total overkill but I've had this cable lying arround from when I was going to boot mount my battery but couldnt be bothered.
The cable from the battery to the starter is just the starter to engine bay remote battery terminal cable, the rest I'm making out of the battery to remote battery terminal.
[Oo=w=oO]Golf GTD
VW Diesel Mehr Kraft. Weniger Verbrauch, Aus Liebe zum Automobil
