Author Topic: low coolant sensor wireing  (Read 2700 times)
April 05, 2010, 08:23:15 pm
madrogers
  • 165
« on: April 05, 2010, 08:23:15 pm »
was thinking of hooking up a low coolant level sensor /lite in my caddy but cannot find much info about it.
the wires from the sensor in the colant tank run into the cab then into a modual or right into the cluster ? I have a mk 2 cluster w/lite in it . does any one have a wireing diagram? the books i have are very basic and show no details of this.
thanks.
83 CADDY 1.6 TD WINTER
83 CADDY 1.9 AAZ SUMMER
Reply #1May 17, 2010, 08:24:43 am
lovinthedeez
  • 489
Re: low coolant sensor wireing
« Reply #1 on: May 17, 2010, 08:24:43 am »
my mk1 has it running through the fuse box.  i know that because I pull the fuse to keep the light from blinking after I swapped in a newer electrical setup that has the provision.  you need the wires?
