Author Topic: Paper gaskets in 100 mm cv joints  (Read 9600 times)
April 05, 2010, 09:13:21 am
Dakotakid
  • 1240
« on: April 05, 2010, 09:13:21 am »
Perhaps a stupid question:
Why did VW employ paper gaskets in 100 mm. inside cv joints???
Reply #1April 05, 2010, 11:49:39 am
Re: Paper gaskets in 100 mm cv joints
« Reply #1 on: April 05, 2010, 11:49:39 am »
to keep the grease in there. and to keep the grease/oil mix in there when those stupid rubber/metal dust caps from the center of the flange starts to leak.
if you leave them out, you will figure out why VW put them there in very short order. lol
Reply #2April 05, 2010, 03:58:38 pm
« Reply #2 on: April 05, 2010, 03:58:38 pm »
Then why don't the 90mm ones have them?
Reply #3April 05, 2010, 04:02:38 pm
Powered by Spearco
  • 1203
« Reply #3 on: April 05, 2010, 04:02:38 pm »
Yeah, huh.  ;D What he said, ^
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #4April 05, 2010, 04:40:23 pm
truckinwagen
  • 1895
« Reply #4 on: April 05, 2010, 04:40:23 pm »
you will only have issues with leakage if the rubber input drive seal fails inside the drive flange, and I would argue that it is a good thing for them to leak when that happens, so you notice it before the CV is trashed.
I have never used a paper gasket when re-assembling, and never had any issues...
83 Opel Kadett Diesel
Reply #5April 05, 2010, 05:51:24 pm
« Reply #5 on: April 05, 2010, 05:51:24 pm »
So gear lube in the cv joint will trash it?
I had one of the little caps leak when, for some reason the axle shaft and tranny output shafted were too close and rubbed a hole right in the middle of the cap. And it did fill the cv with gear lube.....
Reply #6April 05, 2010, 06:06:13 pm
rallydiesel
  • 1880
« Reply #6 on: April 05, 2010, 06:06:13 pm »
I'm pretty sure my 90mm replacement axles had the sticker-type paper ones.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #7April 05, 2010, 07:43:55 pm
GEE-BEE
  • 1604
« Reply #7 on: April 05, 2010, 07:43:55 pm »
another product I need to make out .020 reinforced silicone...
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #8April 06, 2010, 08:45:26 am
« Reply #8 on: April 06, 2010, 08:45:26 am »
my axles in my rabbit had them the first time i disassembled it, they were 90mm. and it had a 4 speed gear mixer in it. about half of them that i see have the paper gasket.
and owen, how will 90wt leaking into the CV destroy it? its got grease in there already, whats the difference if the grease gets thinned down a little bit? ive had about 4 different CVs fill up with 90wt, and all i ever do is clean the gunk out, and re-pack the joint.
Reply #9April 06, 2010, 09:22:55 am
truckinwagen
  • 1895
« Reply #9 on: April 06, 2010, 09:22:55 am »
the stresses a cv joint sees are very extreme, the cv grease is specially formulated for those stresses, regular grease wont do.
when the cv grease is diluted by gear oil, it is not as effective at lubricating and protecting the cv from the immense stress it sees. if allowed to sit with gear oil in it the CV will fail prematurely.
Reply #10April 06, 2010, 09:35:21 am
« Reply #10 on: April 06, 2010, 09:35:21 am »
Weird. All the 90mm ones I have seen except the new (chinese :shudder:) one I bought didn't have gaskets. None of them leak either.
Of the cars I've pulled apart the inner CV has always been shot when it was mixed with gear oil.
Reply #11April 06, 2010, 09:36:28 am
« Reply #11 on: April 06, 2010, 09:36:28 am »
normal grease works just fine for my CV joints. i have not had an inner CV go bad on me yet.
and i take my sutff apart and put it back together so much that the gear oil/grease in my CVs was never there for long.
Reply #12April 06, 2010, 09:41:05 am
truckinwagen
  • 1895
« Reply #12 on: April 06, 2010, 09:41:05 am »
I will bet that they had either failed recently, or the CV's were on their way out.
regular grease will not protect the CV from wear very well, if regular grease is used the joint wont last nearly as long as it should
Reply #13April 06, 2010, 09:47:54 am
« Reply #13 on: April 06, 2010, 09:47:54 am »
oh, i will take your word on it being different. but its not like im going to go out and get CV joint grease and re pack all my joints. that would be like a 2 day project with as many cars  as i have around here. lol.
Reply #14April 06, 2010, 09:55:55 am
truckinwagen
  • 1895
« Reply #14 on: April 06, 2010, 09:55:55 am »
yep, CV grease is very different, it is moly based and VERY sticky/thick.
regular grease may work for a while, but CV's(and their grease) were designed to last 200,000 miles before they start clicking. you may get 10,000 with regular grease/bathed in gear lube, but that is still a drastically reduced lifespan.
