Author Topic: 1997 AAZ Injection Pump Timing, Clutched alternator pulley?  (Read 4520 times)
April 05, 2010, 01:15:06 am
wpinnix
  • 49
« on: April 05, 2010, 01:15:06 am »
Hello, I recently acquired this AAZ motor out of a 1997 Jetta, I will be putting in an 81 caddy. You can see from this picture, the engine was manufactured in 1996. The injection pump pulley is the adjustable type.
What tool do I use to lock it in place to replace the timing belt? You can see in the picture a square notch in pulley lined up with a round hole in the rear....
I believe the alternator pulley is clutched???....will spin separate from the shaft if given a quick spin by hand and grab. Has the part numbers F225355.6
Also has a K03 turbo.....has play in and out....I plan on rebuilding. Any good places to get rebuild kit and 360 degree bearing thing?
I also am wondering about taking off the wires that run to the top of the injection pump....can I just remove them and have it work?
Thanks for any help,
Bill
Reply #1April 05, 2010, 09:11:11 am
Re: 1997 AAZ Injection Pump Timing, Clutched alternator pulley?
« Reply #1 on: April 05, 2010, 09:11:11 am »
Use a drill bit or something to lock the pump and then use a dial indicator and rotate the pump by the 19mm nut to fine tune the timing. I find 1.9s like 0.88mm-0.95mm advance
Those wires on the top are useless. You can safely delete them.
Reply #2April 06, 2010, 12:07:29 am
xsp2467
  • 122
    • Frankenbuilt
« Reply #2 on: April 06, 2010, 12:07:29 am »
let me know if you need any help with the swap, i can give you a few pointers. I recommend you do the timing belt while the motor is out of the car. Dont forget the tensioner and while the motor is out i would also do the intermediate shaft seal. Your gonna like the AAZ in the truck it hauls a$$. I get all my turbos rebuilt by G-Pop shop they are in Arkansas they do a full rebuild for about $395 and have the 360 degree thrust bearing
Reply #3April 06, 2010, 06:16:08 am
GEE-BEE
  • 1604
« Reply #3 on: April 06, 2010, 06:16:08 am »
Dont forget the tdi crank mod, new aaz hoses ( coolant) autohausaz.com
search 96 golf aaz
you will need the hardline coolant hose to recovery tank
I have some 7 mm hose for you fuel supply to filter and return if needed
Let me know
[email protected]
I also have new intake ducts ( turbo to intake )and the right K7N filter assy # for your install
Where all here to help
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #4April 06, 2010, 11:18:25 pm
wpinnix
  • 49
« Reply #4 on: April 06, 2010, 11:18:25 pm »
Thanks everyone for the pointers.
I have my passenger side motor mount fabricated. I'm doing the timing belt, tensioner, water pump, clutch, seals I can get to.....new hoses for sure. Just waiting on turbo to fab up the downpipe.
A couple of questions:
--Will 1.6 NA injector lines fit the AAZ? I have a new set and would be fortuitous....
--Trying to decide on Turbo (the K03 on there now looks like a screw or nut or something went through the vanes).....I've done some research, but everyone has a different opinion. Don't need much more than stock power, just something that is easy to work with and maybe has adjustable waste gate
Thanks again,
Bill
Reply #5April 07, 2010, 09:32:23 am
« Reply #5 on: April 07, 2010, 09:32:23 am »
The 1.6 lines will fit if you also use 1.6 injectors.  The 1.9 injectors are a bit taller, so they need the correct lines.
The "gotcha" however is the 1.9 injectors are an improved dual-stage design.  They provide better cold starts and less noise.  The AAZ pump has a camplate shaped to work with the 1.9 injectors and may not work as well with 1.6 single-stage injectors.
