Author Topic: Part Number Needed - Drive Plate Bolts  (Read 5350 times)
July 06, 2004, 04:46:45 am
Mikeyworks
  • 260
    • http://www28.brinkster.com/mikeyworks/
« on: July 06, 2004, 04:46:45 am »
Hey gang,
I got the damaged crank out last night...after over a week of delay due to Daddy Duty...and I am listing the parts I will need to buy to put this thing back together.
Among them are the drive plate bolts. I have been told that they are Torque-to-yield bolts. Is that true?  Regardless, one of them got a little chewed up upon removal...so, does anyone know the part number for these?   ETKA didn't list anything that I could find.
Other than the standard seals, bearings, etc. can anyone think of any other bolts or parts I need to replace while I am in there?
Thanks
Mikey
Reply #1July 06, 2004, 05:16:07 am
type53b_gtd
  • 118
    • http://scirocco.cs.uoguelph.ca/gtd/
« Reply #1 on: July 06, 2004, 05:16:07 am »
The newer style bolts (with flanged head) are P/N N 902 061 03.
The torque procedure for the flanged head bolts is 25lb-ft plus 90 degrees IIRC.
The earlier style bolts without flanged heads have a straight torque value (in the neighbourhood of 70lb-ft maybe??)
New bolts should come with blue threadlocking compound appllied - if they do not, use some.  Also clean the oil out of the threads on the end of the crank with a suitable solvent.
Drew
Reply #2July 06, 2004, 05:45:54 am
Mikeyworks
  • 260
« Reply #2 on: July 06, 2004, 05:45:54 am »
Drew,
You don't happen to have a picture or other visualization of the different bolts do you?  I stink at trying to picture things like this in my head.
Mikey
Reply #3July 06, 2004, 05:53:56 am
type53b_gtd
  • 118
« Reply #3 on: July 06, 2004, 05:53:56 am »
Quote from: "Mikeyworks"
Drew,
Mikey
Both bolts have very shallow heads, but the new style has a washer integrated into the head, the old style does not.  Does that help?
Drew
Reply #4July 06, 2004, 06:11:52 am
Mikeyworks
  • 260
« Reply #4 on: July 06, 2004, 06:11:52 am »
Drew,
Here's one that I pulled off my engine...
Mikey
Reply #5July 07, 2004, 12:00:38 pm
type53b_gtd
  • 118
« Reply #5 on: July 07, 2004, 12:00:38 pm »
That's the flanged one - newer style.
Check the Bentley to be sure, but the torque spec is 25lb-ft plus 90 degrees, and the replacements must have threadlocking compound applied.
The correct terminology may be "shouldered" rather than flanged - darned if I know... :)
Reply #6July 07, 2004, 01:27:43 pm
Mikeyworks
  • 260
« Reply #6 on: July 07, 2004, 01:27:43 pm »
Drew,
Thanks again for the assistance... I am ordering some from Impex when I order the rest of my parts...likely this afternoon.
Mikey
