General Information
Troubleshooting
What determines how long glow plug light stays on?
Topic: What determines how long glow plug light stays on? (Read 10830 times)
April 04, 2010, 04:24:38 pm
motomike33y
April 04, 2010, 04:24:38 pm »
In my 91 jetta NA the glow plug light on the dash stays on about 40 seconds. I have a relay w/ #60 which, I understand is the medium fast relay. But..., I tried several other relays from my old 82 rabbits, and the time is still the same. The plugs glow w/in a few seconds when power is on, because I checked before putting my injectors back in a couple months back. I haven't hooked up anything to check lately to see if power is on all the time the light is on, but previously when I've checked, it did. Even when the vehicle has been running, and I shut it off, the light will come on when I turn on the key-my vanagons used to not come on if the engine was warm, and I don't think the rabbits did either. So, maybe bad tem sender? How to check? other suggestions? thanks.
82 vanagon 1.6 waiting rebuild
81 jetta w/dasher 1.5 engine
91 jetta w/ 85 golf 1.6 NA- work in progress suzuki samurai hardtop that may someday be diesel
2012 golf tdi
April 04, 2010, 04:46:27 pm
Re: What determines how long glow plug light stays on?
April 04, 2010, 04:46:27 pm »
Sounds like a broken wire or bad sender. Swap the 2 plugs on the 2 sensors on the coolant flange. If the light stays on for a shorter amount of time and the temp gauge doesn't work then you've just figured it out.
April 04, 2010, 06:19:21 pm
April 04, 2010, 06:19:21 pm »
Yup, 40 seconds is pretty much the "as long as possible" time for most relays.
Your relay thinks it's really cold out... so as Burn says, either a dead coolant sender or an issue with the wiring between the sender and the relay.
April 05, 2010, 10:29:44 am
vwjunkie53
April 05, 2010, 10:29:44 am »
If the sensor doesn't cure the problem, I would ohm out all your plugs. I had a weird problem with my engine, all of a sudden the gp light would stay on for much longer than you would expect, even on a warm morning in the summer when it would have normally only lit for maybe 5 or 10 seconds. It turned out one of my glow plugs had gone bad, but still had resistance rather than having no continuity. The ohm reading was super high, and for some reason that extra load on the relay made it stay on for a long long time. I changed the plug and it was back to normal.
Just a thought.
Jason
1984 Volvo 760 GLE, "built" D24T w/ARP studs, MLS head gasket, ported/polished head, 3 angle valve job, NA cam, 56mm T3/T4, NA manifold, FMIC w/ 3" alum piping, 3" turbo back, detailed in CAT yellow. T-5 manual swapped w/ Clutchnet 6-puck. Best of 16.07@86mph with orig. worn out engine.
April 05, 2010, 01:50:37 pm
April 05, 2010, 01:50:37 pm »
Have a look at the connector for the sending unit. For one thing it's one of those weird button type plugs that loosen easily, it's 20 years old and diesel engines vibrate a lot. It probably isn't making good contact anymore.
April 06, 2010, 08:14:01 am
motomike33y
April 06, 2010, 08:14:01 am »
coolant flange has two two wire plugs coming out, so can't easily try that. I'll check out the fastener, then see if I have another sender around. Any differences between the one pin sender unit for this and various other temp senders(same type of connector)?
2012 golf tdi
April 06, 2010, 09:42:15 am
April 06, 2010, 09:42:15 am »
Aren't the 2 wire style conenctors both the same?
I think there are some ohm vw temp specs in the bentley for testing them
April 06, 2010, 11:40:52 am
motomike33y
April 06, 2010, 11:40:52 am »
nope, the one on the end of the head is the slide-over single wire, and the two on the front of the head are each brown wire plus two colored wire going into a plug(2 separate plugs ie 4 wires) which goes into the flange coming out of the head.
2012 golf tdi
April 07, 2010, 12:16:14 pm
April 07, 2010, 12:16:14 pm »
Quote from: motomike33y on April 06, 2010, 11:40:52 am
IIRC that is the one which controls the glow plugs.
I'm not sure how different the wiring is across model years but I think it's fairly similar.
April 07, 2010, 03:55:23 pm
April 07, 2010, 03:55:23 pm »
I was thinking that one was for the A/C.
Are the two on the front of the head interchangeable?
April 08, 2010, 05:18:59 am
motomike33y
April 08, 2010, 05:18:59 am »
yes, it has non-working ac, so both plugs on front are the same-just different colored wires
2012 golf tdi
Reply #11
April 08, 2010, 09:59:02 am
Reply #11 on:
April 08, 2010, 09:59:02 am »
That's debatable. Some say the same, some say slightly different. They are close enough to be interchangable though.
Reply #12
April 08, 2010, 11:01:29 am
motomike33y
Reply #12 on:
April 08, 2010, 11:01:29 am »
I'll try switching them, but I had placed them based mostly on wire length
2012 golf tdi
General Information
Troubleshooting
