Author Topic: Another use for your Dial Indicator--Finding TDC with it  (Read 12735 times)
March 29, 2010, 09:43:56 pm
AudiVWguy
« on: March 29, 2010, 09:43:56 pm »
A couple of years ago when I installed the 16v lightened flywheel I found out it didn't have the right TDC mark. Here's what I did to check TDC. Rotate the engine to the TDC mark on the flywheel (cyl #1). Pull the #1 injector. Loosen the nut on the glow plug a little. Unscrew the glow plug most of the way out to get it out of the way. Extend your dial indicator with a piece of coat hanger or similar of metal. Preload to about 2.5 mm. Now, rotate the crank. the dial indicator will stop at TDC, and then move again as you pass that point. In my case, TDC on the dial was not correct on the flywheel (the pointer in the transmission hole). I made a new mark with my Dremmel tool and was good to go.This is critical for very accurate pump timing.
I hope this helps.
Cheers,
-JB
Reply #1March 29, 2010, 09:51:16 pm
  • 3255
    • My collection of HOWTOs
Re: Another use for your Dial Indicator--Finding TDC with it
« Reply #1 on: March 29, 2010, 09:51:16 pm »
Good one... thanks for posting... "don't have a reliable mark on my flywheel" comes up often.
Moved to the FAQ section. ;)
Reply #2March 29, 2010, 10:16:26 pm
lovinthedeez
  • 489
« Reply #2 on: March 29, 2010, 10:16:26 pm »
i've never seen a magnetic vise like that before.  that's awesome ;D
Reply #3March 31, 2010, 07:01:40 am
moTthediesel
  • 194
« Reply #3 on: March 31, 2010, 07:01:40 am »
That's a great tip!
I have a hybrid flywheel on my engine (Kennedy A/C VW) and I've never been absolutely sure of my TDC mark. This winter I made a "mental note" to check it before I put the head back on.
Of course, as we all know, "mental notes" are not worth the paper they're not written on, which lead to another Homer Simpson "DOHH!" moment shortly after torquing the head  >:(
'82 LandCruiser Diesel Conversion
4Cylinder 3B/KKKturbo/AudiIntercooler(gone, BNF)
'92 Dodge/Cummins D350 Getrag Dually
356 w/Quantum 1.6TD (73 mpg!)
'85 BMW 524td (Der Komisar)
'00 Jetta TDI 5spd
Reply #4September 08, 2010, 01:16:06 pm
vako
  • 187
« Reply #4 on: September 08, 2010, 01:16:06 pm »
will it be possible to use this method on 1.9td (aaz)? because am going to use suzuki flywheel on my engine and i will no more have tdc mark on it.
Reply #5May 16, 2015, 06:08:33 pm
goomicoo
  • 2
« Reply #5 on: May 16, 2015, 06:08:33 pm »
Doesn't the piston linger at TDC for a couple of degrees of crank movement?
Reply #6May 16, 2015, 08:55:29 pm
« Reply #6 on: May 16, 2015, 08:55:29 pm »
Yes. You're better off using something as a piston stop (say a valve) and then turning the crank till it makes contact, marking, turning it back the other way till it makes contact, marking again. True TDC will be directly in the center of your two marks.
Reply #7May 17, 2015, 11:48:59 am
« Reply #7 on: May 17, 2015, 11:48:59 am »
I've used the liquid and clear tube method a couple times and find it to be incredibly accurate and very easy.  That way just one glow plug or injector needs to be removed.  Glow plug #4 is easiest and has the same crank TDC as #1.
