Author Topic: EGT limit?  (Read 6091 times)
Reply #15March 30, 2010, 04:44:24 pm
Re: EGT limit?
« Reply #15 on: March 30, 2010, 04:44:24 pm »
I have a k03 turbo. there's really no lag on my car
no lag in your boos, I mean lag in your gauge as the snail has to heat up before a real reading can take place.
...and the bigger issue is that the turbo is a variable heat remover.  Depending on how hard it's working it will extract varying amounts of heat out of the exhaust stream (which it turns in to compressor energy) so measuring the temp post-turbo will result in a misleading figure that varies in terms of how much it's misleading you.   ;)
Reply #16March 30, 2010, 05:09:29 pm
Doakster
  • 291
Re: EGT limit?
« Reply #16 on: March 30, 2010, 05:09:29 pm »
I can hit 1200 pretty easy if i'm going up a hill....and that's with a 2.25 down pipe and exhaust system...i tend to back out of it at 1100-1200, my new Giles pump definitely is putting out more fuel than stock
Got to get an intercooler soon.
« Last Edit: March 30, 2010, 05:19:58 pm by Doakster »
1991 VW Jetta 1.6TD (Formally an ECO), Giles LDA Pump and Injectors, Techtonics 2.25" Down Pipe and Exhaust system, Rebuilt Trans with 3.94 final drive and a Peloquin Limited Slip Diff, Front H&R Sport Springs, MK4 VR6/1.8T front brakes, Single Round Headlight Conversion.
Reply #17March 30, 2010, 06:57:56 pm
Re: EGT limit?
« Reply #17 on: March 30, 2010, 06:57:56 pm »
My brothers AAZ regularly hit 1600 pre turbo. He did throw a rod through the block though, not sure if it is related or not. His head did have cracks from the precups to valves. Again, not sure if it was related. The car also ran WVO at one point in it's life.
Reply #18March 31, 2010, 02:47:19 am
Otis2
  • 191
Re: EGT limit?
« Reply #18 on: March 31, 2010, 02:47:19 am »
The authors of Volkswagen's SAE paper on the 1.6TD ran their tests to 820 C, or 1500 F, pre-turbo.
From http://www.4crawler.com/Diesel/SAE/vwtdsae.shtml
Figure 50 shows lines of constant turbine inlet temperature and Figure 51 turbine exit temperature. The maximum turbine inlet temperature, which is difficult to measure, is approximately 820 C.
Reply #19March 31, 2010, 01:00:31 pm
VW Smokr
  • 114
Re: EGT limit?
« Reply #19 on: March 31, 2010, 01:00:31 pm »
Although it's not yet really melting into puddles, the Inconel alloy of the turbine wheel starts to deform at around 1600o F, so that temperature can potentially can give a whole new meaning to the term, "blowing chunks"!
IMHO the rod through the block is usually oil starvation combined with over-revving. Personally observed that on a bone-stock 1.5L n.a. that was over-revved on a downshift!
J.R.
SoCal
Reply #20March 31, 2010, 03:04:37 pm
nime01
  • 14
Re: EGT limit?
« Reply #20 on: March 31, 2010, 03:04:37 pm »
My intercooled Eco Diesel reached 804°C during a long pull up a hill in 5th gear, measured with pre-turbo EGT probe & instrument from Auber.
What can I do to lower the EGT?
- will a larger diameter exhaust system help? Still running original cat & exhaust from 1991.
- the original K14 turbo produces relatively hot air at 20 PSI, will a T3 turbo be better?
- washer fluid injection post-IC?
Reply #21March 31, 2010, 07:29:41 pm
rabbid79
  • 684
Re: EGT limit?
« Reply #21 on: March 31, 2010, 07:29:41 pm »
Yes, doing any/all of those will help your EGTs.
'15 WRX
Reply #22April 01, 2010, 01:23:04 pm
Re: EGT limit?
« Reply #22 on: April 01, 2010, 01:23:04 pm »
750-850 F at highway cruise, will go as high as 1200 or so up a hill without downshifting and low boost.
Non-squirted also, but Swaintech coated.
Stock VW T3, 2.5" turbo-back, non-intercooled and stock boost levels right now.
Fueling is, eh, "a bit more than stock".  :D
Reply #23April 02, 2010, 08:59:02 am
dennis
  • 311
Re: EGT limit?
« Reply #23 on: April 02, 2010, 08:59:02 am »
I dropped about 200 degrees after installing a small intercooler from an old Mercury Capri. 70 mph part load.
1980 Caddy TD (Always in progress)
1983 Volvo 245 D24 NA Building D24T
1980 Air-cooled Westy
1956 F100 (What to do???))
