Author Topic: why didn't VW ...  (Read 6499 times)
March 23, 2010, 11:11:51 am
  • 3468
    • McScrubbins Body Wash
why didn't VW ...
« on: March 23, 2010, 11:11:51 am »
Why didn't VW make the 1.6s and 1.9s from the factory with much bigger unrestrictive exhausts and all of their TD's intercooled?
It just, to me, seems like they shot them selves in the foot with that dinky down pipe and no cooling of the boost? the GTD had an intercooler yes but why not all of them?
was alluminium too expensive at the time?
I've found with my big exhaust and ESPECIALLY the IC my car runs 20%-30% more efficiently and scored TWICE as "clean" as it did without the IC on the emissions control test where I live. Not to mention the massive power increase when needed.
ideas?
Reply #1March 23, 2010, 11:20:24 am
truckinwagen
  • 1895
Re: why didn't VW ...
« Reply #1 on: March 23, 2010, 11:20:24 am »
they didnt want to spend any more money on them.
if they did spend the extra money on the car, they would not have been able to make enough extra selling them that way, so they did not.
-Owen
83 Opel Kadett Diesel
Reply #2March 23, 2010, 11:49:47 am
« Reply #2 on: March 23, 2010, 11:49:47 am »
They did actually... Intercoolers and a slightly bigger exhaust became standard on their next versio of diesel engine.
Reply #3March 23, 2010, 11:55:16 am
« Reply #3 on: March 23, 2010, 11:55:16 am »
Because they were making the "people's car."  I know that sounds silly but I think they took that mentality a little to far sometimes.
Reply #4March 23, 2010, 01:11:50 pm
  • 3468
« Reply #4 on: March 23, 2010, 01:11:50 pm »
Ahhhh so i seee.
Hence why the TDI's are a much "nicer" platform to build off of then.
I secretely cry at night wishing my car was direct injection... i'd go all out with the propane, NOS, my huge holset turbo, the whole works...
Reply #5March 23, 2010, 03:18:37 pm
« Reply #5 on: March 23, 2010, 03:18:37 pm »
I've got both TDI (ALH 2001)  and an IDI (AAZ 1994) engines side by side in my shop at the moment, down to the elemental pieces... and it's kinda interesting from a CSI:Volkswagen forensic point of view to see the subtle changes over an entire decade of evolution.
On the TDI... intercooler, bigger exhaust, no prechambers to fall out, no IM shaft or bearings, water pump driven by the timing belt finally, one serp belt to rule them all
On the IDI.... no big thick wiring harness(s) everywhere... simple simple simple... tons of space in the engine compartment to work... no computer needed to play with engine settings !
Everything else kinda looks like the engine that I had in my 1979 Rabbit... just decades of slow evolutionary change.   ;)
« Last Edit: March 23, 2010, 04:21:44 pm by Vincent Waldon »
Reply #6March 23, 2010, 04:20:02 pm
« Reply #6 on: March 23, 2010, 04:20:02 pm »
It's probably worth mentioning that you are talking about the ALH, not the AHU/1Z which are very different ;)
Reply #7March 23, 2010, 04:21:13 pm
« Reply #7 on: March 23, 2010, 04:21:13 pm »
Yeah.. AHU is kinda that intermediate step... in between yet again.
And then there's the current gen common-rail... I wonder if there are any bolts that are the same?!   ;)
Reply #8March 23, 2010, 04:32:07 pm
  • 3468
« Reply #8 on: March 23, 2010, 04:32:07 pm »
Mmmmmmmmmm common rail.
Why does the TDI HAVE to have a computer?
could you not have a production m-TDI?
i suppose that is what the big hoo-ha is all about right now isn't it.
building a working m-TDI?
Reply #9March 23, 2010, 04:42:17 pm
« Reply #9 on: March 23, 2010, 04:42:17 pm »
Always fun to second-guess someone else's decisions... but at a minimum I'd say that for sure cars after 1996ish sold in North America *had* to support OBD-II and a variety of emissions-related readiness codes therein in order to be legal, so the ECU became mandatory by emission law if nothing else.
When you actually start to play with the TDI ECU it is a lot of fun and of course much much easier to tweak things with software then trying new shims, springs, etc etc etc... computers can't be beat from a tuning flexibility perspective.  The system is remarkably well integrated with the chassis as well.. on my latest car I know to expect a dodgy connection at the passenger door for the speaker wire and an issue with the connector to the driver's side power mirror... and I've never actually turned either of them on or had either system apart yet.  The ECU also warned me that I was going to find a lot of carbon in the intake manifold (I did) and that injector #3 was getting worn (and I've posted the pictures of that poor blow-torched piston).
Reply #10March 23, 2010, 04:48:39 pm
  • 3468
« Reply #10 on: March 23, 2010, 04:48:39 pm »
Interesting... I dread to see what my pistons look like. Probably a cold lava flow.
Reply #11March 23, 2010, 06:57:04 pm
« Reply #11 on: March 23, 2010, 06:57:04 pm »
It doesn't. The LT in Europe is a mTDI from the factory. I think it's the LT anyways...
