Author Topic: WOOHOO!!!  (Read 5584 times)
March 23, 2010, 12:39:27 am
79rabbit4dr
WOOHOO!!!
« on: March 23, 2010, 12:39:27 am »
got myself a 1980 1981 (according to the VIN) Caddy!!!
drove 200 miles to buy it then drove it home. needs a little tuning and some restoration but it's in pretty good shape (dash isn't even cracked!!!). Basically a 1 owner.
will post pix when i have two seconds to breathe and have some fun time.
(currently w/o front bumper)
« Last Edit: May 07, 2010, 11:34:49 pm by 79rabbit4dr »
Reply #1March 23, 2010, 12:41:11 am
79rabbit4dr
Re: WOOHOO!!!
« Reply #1 on: March 23, 2010, 12:41:11 am »
oh, and i'm in the market for some TD parts, preferably the whole shebang of course.
« Last Edit: May 07, 2010, 12:42:19 pm by 79rabbit4dr »
Reply #2March 23, 2010, 05:09:24 am
NintendoKD
  • 931
    dnahtasinoivilboeraweb
    • myspace page
Re: WOOHOO!!!
« Reply #2 on: March 23, 2010, 05:09:24 am »
any preferences???  ;)
you know, decarbonated beer is a better coolant than the stuff you buy at the auto store, and is better for you...... really
"If the boost were to rise then the throttle would remain in the wide-open throttle position, which might be fun, but probably not for long"Libbypapa
Reply #3March 23, 2010, 11:51:50 am
79rabbit4dr
Re: WOOHOO!!!
« Reply #3 on: March 23, 2010, 11:51:50 am »
Reply #4March 23, 2010, 12:18:04 pm
Re: WOOHOO!!!
« Reply #4 on: March 23, 2010, 12:18:04 pm »
 ??? It's still for sale
That's a TD setup, not TDI though
Reply #5March 23, 2010, 08:44:01 pm
79rabbit4dr
Re: WOOHOO!!!
« Reply #5 on: March 23, 2010, 08:44:01 pm »
well call me a retard (x2), I thought I saw it was sold... and I was surfing CL for TDI wagons so they was on the brain... sent you PM.
Reply #6May 06, 2010, 11:11:26 pm
79rabbit4dr
Re: WOOHOO!!!
« Reply #6 on: May 06, 2010, 11:11:26 pm »
OP updated. Finally got pix uploaded.
Reply #7May 06, 2010, 11:27:59 pm
GEE-BEE
  • 1604
Re: WOOHOO!!!
« Reply #7 on: May 06, 2010, 11:27:59 pm »
New tailgate on ebay
Lower dash  panels are easy to find also
get some cabby  (LX) remote mirrors, TMI products door panels and some cabby armrest and your off...
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #8May 07, 2010, 12:26:36 pm
79rabbit4dr
Re: WOOHOO!!!
« Reply #8 on: May 07, 2010, 12:26:36 pm »
I only saw one for $150 and it wasn't much better than this one...
couldn't find any on ebay
I had the remotes on my last rabbit and I didn't care for them too much but the TMI stuff I'd check out. Got a link?
***EDIT***
found it:
http://www.vwupholstery.com/products.html
« Last Edit: May 07, 2010, 12:38:57 pm by 79rabbit4dr »
Reply #9May 07, 2010, 01:10:03 pm
GEE-BEE
  • 1604
Re: WOOHOO!!!
« Reply #9 on: May 07, 2010, 01:10:03 pm »
NEW Tailgate :  EBAY:300423831385, wants too much 600.00 reserve
I have some BBS 15 x 6 on ebay myself, fresh powdercoat with new cap's, perfect for that truck !
EBAY 270574615327
I would do  a rhinoliner on your bed or the bedrug.
Iam working on a bedrug for the caddy in the next few weeks , will be bottom ONLY ( no sides ) with the tailgate included.
bedrug.com has some info...
I have rear axle bump stops also ( new production )
tailgate buffers ( rattle ) ebay seller moogie2498
tailgate handle, rabbitparts.com ( black )
You can get a techtonics downpipe and a 2.25 or 2.50 exhaust for it also
DP is S/S in either size
I can help you with batter cable ( positive ) 1/0 size , 24 inches long.  12.50
turbo to manifold boot ( rubber ) now silicone
32.50 with clamp's
I have a extra speedo with 4700 miles on it also ( 1980 ) round, make me a offer
What else ?
GB
« Last Edit: May 07, 2010, 01:18:30 pm by GEE-BEE »
Giles Pump OHC
MK1 JETTA DASH
Reply #10May 07, 2010, 01:46:41 pm
rumbling_caddy
  • 80
Re: WOOHOO!!!
« Reply #10 on: May 07, 2010, 01:46:41 pm »
  Nice!  I just got a diesel caddy last week too.  Mine wasn't running when I bought it so I got a good deal
Reply #11May 07, 2010, 02:06:55 pm
79rabbit4dr
Re: WOOHOO!!!
« Reply #11 on: May 07, 2010, 02:06:55 pm »
First thing on the list is to get it running better;
     -fix the fuel leak, air in the line from somewhere pre-separator.
     -tb, h20 pump, new engine mounts, new gp's and relay, replace fuel return lines (got all the parts from Myke already)
     -check the brakes
Second, send my spare pump to Giles to have it worked over.
Then Tires will be mounted on stock steelies painted black and I've got some chrome center caps to go with them.
Then i'll start on interior;
     -Pull out headliner, saggy and rubs my head, think i'll put in black felt all the way down behind the seats
     -get some black carpet from TMI probably
     -find lower dash parts I need, knee bar, ash tray, glove box (mines cracked at hinges)
Then I've got an idea for a ram-air style hood I want to try out, picture subaru hood scoop but vw fashion/function.
Reply #12May 07, 2010, 02:58:56 pm
GEE-BEE
  • 1604
Re: WOOHOO!!!
« Reply #12 on: May 07, 2010, 02:58:56 pm »
Moogie2498 ebay seller might have the dash parts
TMI now has the patterns for the door panels with the lx mirror holes and 3 pin cabby armrest
dean at tmi will help you
Go with the newton.com carpet kit, all others dont have the kickpanels or the cutouts for the seat rails or the seatbelts or shifter
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #13May 07, 2010, 05:12:27 pm
79rabbit4dr
Re: WOOHOO!!!
« Reply #13 on: May 07, 2010, 05:12:27 pm »
negative, looked through everything, nada.
my door cards are good, at least for now. arm rests are pretty low on the list.
the pdf on TMI shows the kickpanel pieces (I think) and I can cut the other parts out... but I'll check newton.com's kit and compare.
Reply #14May 07, 2010, 06:26:11 pm
GEE-BEE
  • 1604
Re: WOOHOO!!!
« Reply #14 on: May 07, 2010, 06:26:11 pm »
SEND MOOGIE A EMAIL, TELL HIM I SENT YOU !
I make his stuff on contract...
get some feedback on the vortex forum about the TMI stuff
You wont go wrong with the newton carpet, the money you think you will save from TMI or stockinteriours.com, will not make up for it in the time on cutting and fitting and extra material
Iam not sure if TMI does there own ?
I just got my second set of door panels and they forgot to cutout the door handle pull area ( vinyl)material
and forgot my panel clip's ?
another call to make
Giles Pump OHC
MK1 JETTA DASH
