Fixmyvw.com
Author Topic: 1980 cadillac diesel  (Read 7234 times)
March 22, 2010, 11:07:11 pm
  • 1739
« on: March 22, 2010, 11:07:11 pm »
someone came to the shop today with one of these today : [hope the link works]
http://www.flickr.com/photos/that_chrysler_guy/4139796470/#
a 1980 cadillac seville but it was diesel. Didn't have any Canadian or US DOT stickers and the guy said it came from mid east somewhere.  crazy
Reply #1March 22, 2010, 11:38:09 pm
Turbinepowered
  • 1206
Re: 1980 cadillac diesel
« Reply #1 on: March 22, 2010, 11:38:09 pm »
Apparently the Seville was plagued with rotten GM engines when it was re-released in the Eighties. The 5.7 diesel, the 8-6-4, the baby 4.1 V8... :p
Reply #2March 23, 2010, 12:15:12 am
maxfax
  • 2126
« Reply #2 on: March 23, 2010, 12:15:12 am »
Let's not forget the Olds 350 gasser with the port efi and a choke for cold weather  :o  That may have been the 70's come to think of it..
Either way, very cool to see one of these ugly things still going, you tried to buy it, right??  ;D
Reply #3March 23, 2010, 03:34:07 pm
rabbitman
  • 2787
« Reply #3 on: March 23, 2010, 03:34:07 pm »
In this http://www.vwdiesel.net/forum/index.php?topic=24873.0 they have some info about a diesel cadillac
Reply #4March 23, 2010, 07:58:04 pm
  • 1739
« Reply #4 on: March 23, 2010, 07:58:04 pm »
  "you tried to buy it, right?? "
 It was very cool ,but you couldn't pay me enough to own a GM built diesel
Reply #5March 24, 2010, 08:16:30 am
catlin_cava
  • 1954
« Reply #5 on: March 24, 2010, 08:16:30 am »
 :-X burn it?
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #6May 01, 2010, 01:15:17 pm
« Reply #6 on: May 01, 2010, 01:15:17 pm »
Ahh yes, the car that crushed any hopes of diesel powered vehicles becoming mainstream in the U.S.
If I'm not mistaken, the only real problem with those cars (aside from the atrocious power-to-weight ratio) was that GM did not provide an adequate means to remove water from the fuel, something that was critical back then but largely irrelevant now?
Couldn't you get a 300D back then for about the same amount of money?
Reply #7May 02, 2010, 05:18:13 pm
maxfax
  • 2126
« Reply #7 on: May 02, 2010, 05:18:13 pm »
The water separator was a biggie, but there were other issues as well..  On the first generation they cheaped out on fasteners.. Especially the head bolts..  Quality control was rather shoddy too..  IT was nothing to measure the chambers in the heads and find a half CC plus variance between cylinders  :o  The second generation was slightly (and I mean very  slightly) better..     Couple all this with dealer techs who knew nothing about diesel engines and well, we've all seen what happened...
Reply #8July 12, 2010, 02:21:28 am
Toby
  • 728
« Reply #8 on: July 12, 2010, 02:21:28 am »
The real problem with the GM 5.7D was idiots with ether. Every one of them that got traded in went through the used car auctions. Most had weak batteries so EVERY ONE that got run through a used car auction was started/killed with ether. I have seen a bunch of these motors apart and the ether would break the main caps and pull the main bolts out of the block. That and break pistons. The big sign on the air clean said never use ether on these motors but that did not stop the idiots.
I used to specialize in 5.7Ds at my shop and knew how to make them live. The second problem was GMs goofy cooling system in those cars. The top of the radiator was below the heads, but the cap was still on the radiator. That meant that any air in the cooling system collected in the heads and there went the head gaskets. It took several hot/cold cycles to push the air out the cap. A tiny coolant leak and a top up with coolant a few times and you had a HG leak which cascaded into a breakdown. Not the motors fault however. Blame the bean counters. A simple surge tank above the heads for the air to collect would saved 75% of them.
They also had weenie, poor quality head bolts, but these could be replaced with Allen bolts when you changed the HG. The later roller can 5.7s would get 24-28 mpg in a Toronado. The last iteration of the V6 GM diesel had the extra head bolts that it cried out for and was a really good motor. I had one in a full size '83 RWD Cutlas that got a real 43 mpg. I was an idiot to sell that car.
BTW water in the fuel was not the problem. It was some plastic parts in the governor that disintegrated, probably from some of the diesel additives sold back then.
I built a roller cam motor for a friends Olds 88 that had a jimmied pump, a mild port job and a hotter cam. It was a very sweet rig. Lots of power and after balancing the injectors it had a much quieter rumble to it that was really sweet. It kind of snarled at you.
Reply #9July 12, 2010, 10:40:05 am
fdnyguy
  • 499
« Reply #9 on: July 12, 2010, 10:40:05 am »
Wasn't that V6 a Belgian diesel or something? My sister had a 1982 Buick Regal with that diesel v6 and it got awesome mileage (would have been better if the car had overdrive). Some parts went on it and they were hard to get get from Buick. My Brother in law was sorry he got rid of it though.
Nice to see someone with extensive knowledge of the infamous GM diesels. I always thought the biggest problem was using a gas block, not the problems mentioned above. But it still leaves a bad taste in many peoples mouths. 2 guys in my firehouse own hybrids, some won't even think of going near a diesel (their loss), one who does extensive commuting is looking into the Golf TDI, and a pal in another firehouse did buy a Golf TDI after driving my 09 Jetta, but wanted the smaller car. A know irt all female (imagine THAT!!lol) I work with who is into the 'green scene' did not like it when I told her my TDI made less emissions and carbon footprint than a hybrid. Shame is she loves VW's. Her loss.
And a new TDI engine is still cheaper than replacing those hybrid batteries (corrections welcomed).
Stay safe, stay well. Jimmy.
Never forget what a "Religion of Peace" did on 9/11/01.
2015 Passat TDi. 27k
1998 Jetta 1.9TTDi 228k .
2002 F250 7.3 TD   63,000 miles. Sold.
1980 Mack CF Fire Engine. Working on it.
2007 Dodge MegaCab 5.9 Cummins. Nice, but plagued with issues
Reply #10July 12, 2010, 10:50:43 am
OM617
« Reply #10 on: July 12, 2010, 10:50:43 am »
Actually you could buy two caddies for the cost of a 300D.
They never did any such thing.
Reply #11July 12, 2010, 12:59:38 pm
« Reply #11 on: July 12, 2010, 12:59:38 pm »
they never used a gas block, but they started with a gas block, and modified it for use as a diesel block, rather than just building a diesel specific block.
Reply #12July 12, 2010, 02:10:53 pm
rs899
  • 647
« Reply #12 on: July 12, 2010, 02:10:53 pm »
Funny, so did VW with the first 1.5, and IIRC they did it in about 90 days.  And we are still driving them (with a few improvements)....unlike the GMs
Reply #13July 12, 2010, 02:36:29 pm
Toby
  • 728
« Reply #13 on: July 12, 2010, 02:36:29 pm »
No, it was all US made GM stuff. I rebuilt one in a Cutlass Ciera once and it was very nice inside. It had male Torx head bolts for the extra head bolts that you accessed through the intake runners. You had to remove a pipe plug in each of the intake runners to get at them. They had the first "styrofoam" cast parts that I ever saw. (Heads and intake.) Very nice stuff.
Reply #14July 14, 2010, 03:49:04 am
« Reply #14 on: July 14, 2010, 03:49:04 am »
Lets see, in 4 years and 30K miles, my 6.2 has cost me
$100 glow plugs
$20 1 lifter
$20 frost plugs
$7 valve cover gasket
$22 throttle cable.
Hows your VW compare? ;D  Mine have all cost about enough to offset the fuel economy difference.
Fixmyvw.com
