Author Topic: Power Steering Pump going?  (Read 4080 times)
March 19, 2010, 08:25:50 pm
Wayland
  • 364
« on: March 19, 2010, 08:25:50 pm »
The car is an 85 Jetta NA, with power steering. The other day I noticed the steering felt stiffer. The strange thing is, is seems like it's stiffer when the wheels are angled, as for a fairly sharp turn. Closer to the center it feels more normal. The pump isn't making any unusual noises, there are no leaks, and the reservoir is full of oil. Could the PS pump be failing?
84 Grumman Olsen Kubvan
93 Dodge CTD Truck
Reply #1March 20, 2010, 09:06:27 am
Re: Power Steering Pump going?
« Reply #1 on: March 20, 2010, 09:06:27 am »
put some manual steering on there and see how it feels afterwards.
Reply #2March 20, 2010, 07:01:34 pm
Dakotakid
  • 1240
« Reply #2 on: March 20, 2010, 07:01:34 pm »
Could the pump be starting to go....maybe.
What shape are your strut bearings in? As they go, there is a higher amount of resistance.
Just today, I replaced a tie rod end on a manual steering '86 Golf. The one I removed was just starting to have play in it (the rubber was rotted and cracked). So all of a sudden, the thing requires much less effort to steer....much easier to hold a beer now......
Reply #3March 21, 2010, 03:23:43 pm
Wayland
  • 364
« Reply #3 on: March 21, 2010, 03:23:43 pm »
After thinking about it and driving some more, I'm starting to think I might have a U-joint in the steering column siezing up. It's seeming like the stiffness occurs about every 90 deg of steering wheel rotation. I'm going to look into it more tomorrow.
93 Dodge CTD Truck
Reply #4March 21, 2010, 10:57:07 pm
Wayland
  • 364
« Reply #4 on: March 21, 2010, 10:57:07 pm »
Just for fun, I squirted some WD-40 on both steering column U-joints this afternoon, when I drove the car this evening, I noticed the steering was beeter than it's been in a while. I guess I found the problem!
93 Dodge CTD Truck
Reply #5March 22, 2010, 06:00:59 am
« Reply #5 on: March 22, 2010, 06:00:59 am »
its probably just that most of your front end is worn out. rack and pinion probably arent far behind it.
