General Information
Troubleshooting
Oil light goes out before start up.
Topic: Oil light goes out before start up. (Read 4377 times)
March 18, 2010, 10:04:03 pm
Powered by Spearco
March 18, 2010, 10:04:03 pm »
I got an '86 Vanagon with a diesel swap. The oil light used to light up before starting and stay lit till started.
Now it goes out before starting.
I checked to see if the oil light would light up when grounding both wires and engine running, no light or buzzer.
Know I do have to say that I was just in the speedo cluster to fix the Odometer, but what might of happened?
Any ideas?
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
March 19, 2010, 09:03:54 am
Re: Oil light goes out before start up.
March 19, 2010, 09:03:54 am »
IIRC the way it works is as follows:
There is a low pressure sender that opens the circuit when there is oil pressure, that is on the head. There is a high pressure sender (something like 20 PSI) that closes the circuit (to ground) when there is sufficient oil pressure above a certain RPM (2000 I think).
IMO the whole "dynamic oil pressure monitoring" or however VW calls this thing is stupid, problematic and a poor substitute for an oil pressure gauge. I have problems with mine operating erratically, in my case it's caused by poor connections at the plug on the instrument cluster. My temporary solution was to remove the instrument cluster bezel so I can stick my hand in there and push on the plug when it starts to do this.
March 19, 2010, 06:38:32 pm
March 19, 2010, 06:38:32 pm »
Colud have maybe knocked a solder joint loose s well eh?
Sorry for the granarical errors... New iPhone lol and big thumbs
March 19, 2010, 06:43:02 pm
March 19, 2010, 06:43:02 pm »
Quote from: Powered by Spearco on March 18, 2010, 10:04:03 pm
Just to be really clear... does it go out *while* you are cranking, or does it go out all by itself if you just leave the key in the "on" position *without* cranking?
March 19, 2010, 08:53:43 pm
Powered by Spearco
March 19, 2010, 08:53:43 pm »
The light would come on and the off, like a flash.
Now if by some strange auto-fix, now all is working right
Also I knoticed that the dash lights started to work to.
So I know I left something loose. But have you ever seen a good Vanagon instrument cluster that doesn't have all the tabs crusted off.
So that will need to be fixed.
Thanks for your replies.
'13 Golf R:. Tuned
'98 Puch G320
March 21, 2010, 09:42:48 am
Powered by Spearco
March 21, 2010, 09:42:48 am »
Ok. So I took apart the cluster and found that one of the little copper fingers of the trace on the end where the connector fits, had peeled up and rooled back. Not making the right connection.
So I gently unrolled it w/ small paper clip and reinstalled the connector
Now it functions better than before.
I got lucky not having to diag. oil control BS.
'13 Golf R:. Tuned
'98 Puch G320
General Information
Troubleshooting
