Author Topic: F.S. TDI - APR Head Stud Set  (Read 3586 times)
March 14, 2010, 08:07:26 am
ein bora
  • 377
« on: March 14, 2010, 08:07:26 am »
-relisted.
« Last Edit: March 21, 2010, 04:05:18 am by ein bora »
If you can't take advice - then you can't be helped!
Reply #1March 14, 2010, 03:22:07 pm
NintendoKD
  • 931
    dnahtasinoivilboeraweb
    • myspace page
Re: F.S. TDI - APR Head Stud Set
« Reply #1 on: March 14, 2010, 03:22:07 pm »
will these work with any other models as well, just curious? ???
Reply #2March 14, 2010, 04:16:15 pm
« Reply #2 on: March 14, 2010, 04:16:15 pm »
I believe if you check the FAQ these studs will fit most all 12mm VW blocks. It is the one I bought for my 1.6 and it works just fine.
