Author Topic: FS: MK2 1.6td complete  (Read 3864 times)
March 11, 2010, 07:37:17 am
xtrigger
  • 48
    d3lahk
« on: March 11, 2010, 07:37:17 am »
Selling 1.6td engine from 86 mk2 jetta
Comes complete with everything needed to run, and it runs great
(IP, Head, Block, Turbo, all the lines... etc...)
Turbo is in very good shape and boosts well...
Pan is rusty but is fine (dont leak)
Engine has around 311 000kms with new belt, and pump was resealed also
Good motor, Im swapping it out for a Gas engine with carb setup and dont have any use for it....
I ran it daily with 15psi and a few tweecks of the fuel screw, (they are dangerously slow) but after those it wasn't too bad...
The engine can be heard running (will video record it)
Cold starts are fine and no odd colours from the usual (slight white, then it calms down)
it will only smoke a bit at start up and then clear out once warmed up
Doesnt leak oil or burn blue but it does use some up, every 5000kms (per oil change) it uses maybe 1L
Engine isnt pulled yet, and IM just getting a feeler on any interest...
Looking to get $600 complete minus; trans, clutch, starter, alternator (can be negotiated)
$600 OBO (dont be shy)
LOCATED IN London, Ont but I go to school IN Scarborough so I can stuff it in my other mk2 and bring it down....
PM ME or email [email protected]
Pics and Video will be up asap
thanks
« Last Edit: March 11, 2010, 11:15:26 am by xtrigger »
1986 VW Jetta TDI
