Author Topic: 87 Diesel Cabriolet mod  (Read 5038 times)
March 05, 2010, 02:01:28 pm
overdrivegear
  • 120
« on: March 05, 2010, 02:01:28 pm »
There's just some thing awesome about a diesel convertible...
1.6 NA (code ME) Hydraulic lifter head, stock pump, injectors, and nozzles.   AGS transmission with 0.71 fifth.  I used the gasser exhaust and plugged the lambda sensor.  Now I'm working on tidying up the gasser electronics spaghetti and adding a circuit for the glow plugs, indicator on cluster, and relay.
1985 Westy Golf 1.6 NA
1987 Cabriolet (soon to be 1.6 NA)
Reply #1March 05, 2010, 04:53:24 pm
Quantum TD
  • 1195
Re: 87 Diesel Cabriolet mod
« Reply #1 on: March 05, 2010, 04:53:24 pm »
Let us know how those sweet fumes treat you when your rollin with the top down.  IIRC, the wind blows from the rear to the front when you're driving. You may need an airscreen behind the front seats to keep the fumes down.
Good luck.
Reply #2March 05, 2010, 05:13:23 pm
GEE-BEE
  • 1604
« Reply #2 on: March 05, 2010, 05:13:23 pm »
BOSCH has a universal glow plug kit, fast type glow plug's with relay box  , less than 100.00 thru wolrldpac
GB
I had to do the same with the coolant neck for my swap also , gas to AAZ
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #3March 06, 2010, 04:32:01 am
rs899
  • 647
« Reply #3 on: March 06, 2010, 04:32:01 am »
If you don't like the smell of diesel fumes...don't drive one...
My next project (well maybe) is to do something with an '81 Cabriolet that I bought about 2 years ago to do just this conversion.  It had a gummed up fuel system and has a tired 1.7 EN engine.  Just after I bought it, that was when diesel prices went through the roof as opposed to gas, and I thought I had better have myself a gasser in my fleet ( we have 6 diesels that are daily drivers), so I "invested" in two other gasser engines, CIS tester, Weber carb...etc etc.  Now I am sorry I didn't just rebuild a 1.6NA I had lying around and plug it in.  It still may come to that, but I need to do something with these crappy gas engines I bought...
Rick
Reply #4March 06, 2010, 06:10:20 am
lovinthedeez
  • 489
« Reply #4 on: March 06, 2010, 06:10:20 am »
get to work and clean up those wires son  ;D
some of the wiring(and other crap) I pulled out of mine during my swap
but that lead to a needing for clean, so i got the right diesel harnesses....all of em
good luck.  should be fun with spring around the corner
Reply #5March 09, 2010, 10:41:18 am
overdrivegear
  • 120
« Reply #5 on: March 09, 2010, 10:41:18 am »
I got all the basic wiring done which includes the starter, and other heavy stuff.  I'm not going to pull out any old gasoline wiring, but rather I'm going to just pig-tail it all up and zip tie to the bulk of the harness.  I put the gasoline alternator back on it and swapped the pulleys, but I might go back with the diesel alternator with the W terminal so I can eventually have a functional tachometer by replacing all those components on the board.
Do you think I should remove the catalytic converter?  I don't think it's going to hurt anything by being there; obviously it's going to get sooted up but it also does create some back pressure.  Then again, I could get it for scrap value...
Reply #6March 09, 2010, 12:46:25 pm
GEE-BEE
  • 1604
« Reply #6 on: March 09, 2010, 12:46:25 pm »
REMOVE THE CAT, BYPASS PIPE IS EASY TO MAKE
INSTALL FUEL FILTER ON THE RH FENDER STRUT WHERE THE SMOG VALVE WAS BOLTED ON
need a pic
Email me at [email protected]
You should also install a better battery and cables.
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #7March 09, 2010, 07:38:52 pm
OM617
« Reply #7 on: March 09, 2010, 07:38:52 pm »
Diesel soot is healthier than the CO and other poisons g@s engines spew out.
Reply #8March 09, 2010, 08:06:17 pm
« Reply #8 on: March 09, 2010, 08:06:17 pm »
Very true, and I'd rather smell diesel smoke all day over gasser stink anyways ;D. The only problem is if you over fuel it you'll coat the interior with soot.........
Reply #9March 10, 2010, 06:54:12 am
« Reply #9 on: March 10, 2010, 06:54:12 am »
I thought black interiors were the hype? ;)
Reply #10March 12, 2010, 10:50:16 pm
Quantum TD
  • 1195
« Reply #10 on: March 12, 2010, 10:50:16 pm »
Tell that to the inhabitants of Mexico City and Guatemala City (and probably every other major Latin American City). They have absolutely no laws governing air pollution and the air is black with soot. I know maybe 30 people from Guatemala City, and at least 7 of them have had cancer, died from cancer, or have family members who survived or died from cancer. This includes an 18 kid with testicular cancer.
I'd estimate that about 20-30% of the cars on the road in Guatemala City are diesel, and all of the ancient buses are diesel (most people use the buses for transportation).
For comparison sake, I don't know a single person in the US that has been affected by cancer, either directly or indirectly.
« Last Edit: March 12, 2010, 10:53:08 pm by Quantum TD »
Reply #11March 13, 2010, 12:28:02 am
MJF
  • 581
« Reply #11 on: March 13, 2010, 12:28:02 am »
Why is your breather plugged?
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #12March 13, 2010, 06:49:52 am
« Reply #12 on: March 13, 2010, 06:49:52 am »
Plugging the Crank Vent will introduce high pressures inside the engine and oil will start to puke out of every orifice (ie, Dipstick, past the rings, valve cover, and any other old seal in your engine)
I highly recommend taking that little red cap off, and at least venting it to atmosphere.
Reply #13March 13, 2010, 06:53:57 am
« Reply #13 on: March 13, 2010, 06:53:57 am »
I wouldn't worry about it. Without that timing belt covered it probably won't make it long enough to push his seals out. If he drives on roads like I have around here.
Reply #14March 13, 2010, 12:26:20 pm
« Reply #14 on: March 13, 2010, 12:26:20 pm »
X2 in the timing cover. they are there for a reason, and the reason is not just to look ugly.
