Author Topic: FS: 1996 Passat TDI Wagon. B4V. Southern US car.  (Read 5430 times)
March 04, 2010, 06:34:12 pm
CdnVWJunkie
  • 309
« on: March 04, 2010, 06:34:12 pm »
For Sale:
1996 VW Passat TDI Wagon   AKA: B4V.   Nearly legendary status.  25 Gallon/95 Litre fuel tank which allows 1000 Mile/1600 Km between fuel ups.  240K miles/400 TKM.  Southern US car.
Mechanical:
- 1.9L Turbo Diesel Engine.  Code AHU.  From '98 Jetta  147K miles/235 TKM
- 5 speed manual transmission.  02A Code CTN.  From '98 Jetta. 147K miles/235 TKM.
- New: TB, rollers, tensioner and crank bolt.  H20 pump and thermostat.  All 3 motor mounts,  N75 wastegate valve is fresh.  All from TDIParts.com.
- Rebuilt Bosch Alternator.
- Intake manifold recently cleaned.
- Low mileage AFN 110 hp European injectors.
- Passes emissions test with flying colours.
- Brakes are freshly serviced.  New front rotors and pads.  Rears were cleaned, inspected and reinstalled as they were 75% or better.
- Exhaust is sound front to rear.
- 4 wheel alignment.
- ECM has been upgraded to a GQ
- 5th injector delete
- All fluids and filters have 500 KM/300 Miles.
- New battery.
Exterior:
Clean South Carolina car.  No northern winters here.  Solid rust free undercarriage and body.  Only one small spot of rust on the front right wheel arch.
- A few small dings and one rear dent but all in all above average condition for a vehicle this age.
- 14" Jetta GT alloy wheels with very good 205/60 R14 Pirelli rubber.
-  Sunroof works properly and is whistle and leak free.
- Clean headlamps.
Interior:
- Clean beige cloth interior.  Well above average condition.
- Carpet was removed and steam cleaned.
- Brand new heater core and rebuilt heater box.
- Clarion CD stereo.
- All four windows regulators work properly.
- All gauges and warning lamps function properly.
- AC blows ice cold.
Misc:
- Loaded: including power steering, brakes, windows, cruise, tilt.
Comments:
 The cars runs and drives very well.  These cars have timeless lines.  It drives very smoothly.  The engine has very nice power certainly much stronger than stock.  The transmission shifts smoothly.  The brakes feel very solid including the emergency.  Steering is tight and responsive.  All replacement parts, filters and fluids have been OEM or equivalent.  This is a factory TDI car not a converted unit.  This is a US import and could easily be brought back into the US.  This car isn't cosmetically perfect but it's very strong mechanically and the body is very solid and nearly free from rust.  This could be a nice long term car for someone given the right care.  A service history file from the previous owner will be included with the sale.
Sale Pending....
Blems:
-Small rust blister above right front wheel arch- only spot on car.
- Small dent below rear window.
-Chalky paint on left rear door.
-Chalky paint on left front corner and bumper scuff.
« Last Edit: April 01, 2010, 03:15:55 pm by CdnVWJunkie »
