Author Topic: Throttle Shaft Leak Repair - A Question....  (Read 4822 times)
February 28, 2010, 04:25:40 pm
Frank06
  • 14
« on: February 28, 2010, 04:25:40 pm »
'86 1.6 Jetta with leak around the throttle shaft.  I've removed the *@#&*!* springs and started to push the shaft out through the cover, hoping to see the o-ring.  It seems to be binding a bit on something and I'm not sure how to proceed.  There is some sort of vertical shaft at the rear of the pump with a spring that doesn't let me tip the cover very much to investigate.  Can I remove this?  (What is it anyway?)
Tips, hints, advice, etc. appreciated!
Frank
Reply #1February 28, 2010, 04:42:59 pm
Re: Throttle Shaft Leak Repair - A Question....
« Reply #1 on: February 28, 2010, 04:42:59 pm »
http://www.vwdieselparts.com/forum/viewtopic.php?t=6694&postdays=0&postorder=asc&start=0  Toward the bottom of this post are some pics of what is in there.
Is yours a turbo pump?
this is the o-ring
Reply #2February 28, 2010, 04:59:06 pm
Frank06
  • 14
« Reply #2 on: February 28, 2010, 04:59:06 pm »
It's a normally aspirated engine.  It sounds like if I remove the vertical shaft on the engine side of the pump that I should be able to remove the cover away from the shaft and access the o-ring.  Does this sound right?  (Thanks for the picture.)
Reply #3February 28, 2010, 05:07:39 pm
« Reply #3 on: February 28, 2010, 05:07:39 pm »
You push the shaft into the cover as you pull the cover away from the pump.
then you can unhook the governor.
it is a fiddly proceedure.
Reply #4February 28, 2010, 05:16:32 pm
Frank06
  • 14
« Reply #4 on: February 28, 2010, 05:16:32 pm »
OK thanks - do you know what function the vertical shaft serves?  That seems to be making it hard to tip the cover.  Maybe I just have to try harder....   :D
Reply #5February 28, 2010, 05:23:42 pm
wolf_walker
  • 1205
« Reply #5 on: February 28, 2010, 05:23:42 pm »
That thing has the cold start raise the idle linkage on the backside of the pump don't it?  There is a spring and some other stuff in there under the cover if so making it harder to remove.  You can unhook it somehow, can't remember off hand.
Mentat Text Two
Reply #6February 28, 2010, 05:43:00 pm
Frank06
  • 14
« Reply #6 on: February 28, 2010, 05:43:00 pm »
I wonder?  The cold start has been disconnected so maybe I don't even need it...   ???
Reply #7March 01, 2010, 09:59:46 am
« Reply #7 on: March 01, 2010, 09:59:46 am »
Cold start advance and fast idle are two very different things.
